Old 06-23-2008, 03:07 PM   #1 (permalink)
lonestarbuzz
lonestarbuzz's Avatar
Modifry vs. PAC
Any thoughts? I want to change my head unit but keep dash controls. PAC is cheaper - is Modifry's DCI worth it?
thanks in advance!
i need a better signature.
Old 06-23-2008, 04:26 PM   #2 (permalink)
RL1924
Do you have a link to this PAC new to the S2000 heard of the other and i was going to buy it but cheaper sounds better to me lol
Old 06-23-2008, 06:43 PM   #3 (permalink)
lonestarbuzz
http://www.crutchfield.com/S-APjVVc1...x?i=127SWIJACK
Old 06-23-2008, 07:59 PM   #4 (permalink)
SupeR_DavE
S2k Driver
SupeR_DavE's Avatar
good question I like to know as well,love to save some money
SupeR_DavE is offline   Reply With Quote
Old 06-23-2008, 08:01 PM   #5 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
I was under the impression that they both did the same thing. Haven't used one but that is what I was told..
Old 06-24-2008, 07:27 PM   #6 (permalink)
Sikocivic
Sikocivic's Avatar
I have the Modifry unit on my Alpine. Works great and it was plug & play.
Sikocivic is offline   Reply With Quote
Old 06-24-2008, 08:34 PM   #7 (permalink)
Modifry is a great guy and someone I recommend.
Old 06-25-2008, 07:23 AM   #8 (permalink)
lonestarbuzz
i guess that's what i needed to hear. thanks guys!
Old 06-25-2008, 07:56 AM   #9 (permalink)
SDHonda
Dazed and Confused.
Send a message via Yahoo to SDHonda
I agree, the Modifry unit is awesome. Plugs right in and works out of the box.
SDHonda is offline   Reply With Quote
Old 07-28-2008, 04:37 PM   #10 (permalink)
s2ksuzuka
s2ksuzuka's Avatar
The Modifry unit is the way to go. the PAC has delays and does not have all the functions that the Modifry has. The Modifry is a far superior piece. Buy his radio plug, and then it is truly plug and play. If your radio has the steering wheel control jack in the back, make sure to get the wired version from Modifry.
Mitch
Mitch
2002 S2000 346 RWHP
2006 Element "Boximus Maximus" Stock except for electronics
s2ksuzuka is offline   Reply With Quote
Old 07-29-2008, 07:41 AM   #11 (permalink)
lonestarbuzz
thanks, Mitch. I got the Modifry and installed it a few weeks ago. It's been great. I bought an Alpine head unit and got the wired plug-n-play harness. It was a breeze to install.
I did notice, however, that the 3.5 mm jack that plugs into the back of the HU would come loose. This happened about three times. I had the pull the HU each time to fix it. Finally, I took a small bit of electrical tape (about 1 mm wide) and wrapped it around the base of the jack (right next to the rubber) twice. This made the jack fit much more snuggly and I have had no problems since.
