Old 06-28-2009, 03:26 PM   #1 (permalink)
Roger_Rabbit
Roger_Rabbit's Avatar
Stereo Removal
I was trying to remove my stereo to install an aftermarket unit and there are 2 brackets screwed to the side of the factory stereo... How do I get this thing out or get these brackets off...
Edit:
I posted a picture as requested... I circled the problem brackets with red... While I am at it I circled the little latch doo-hickey in blue... Does anyone know where to buy one of those...?
Roger_Rabbit is offline   Reply With Quote
Old 06-28-2009, 03:48 PM   #2 (permalink)
J'sS2K
J'sS2K's Avatar
Post up some pix bro!
www.getgopod.com
Old 06-28-2009, 04:13 PM   #3 (permalink)
Raconteur
You need to remove more then the door...that whole assembly from the vent ducts to the front of the console comes out. Once you remove that, it's easy to get to the screws that hold the brackets in place.
Old 06-28-2009, 04:28 PM   #4 (permalink)
RL1924
RL1924's Avatar
Yea i dont even know how you got the door off... The door will come off with the whole setup which is just held in with.. not sure what there called but just clips if you pry from the top with a pry tool or screwdriver it will pop out
Old 06-28-2009, 04:29 PM   #5 (permalink)
Roger_Rabbit
Wow... Thats crazy...
Old 06-28-2009, 04:38 PM   #6 (permalink)
RL1924
RL1924's Avatar
lol yup always an easier way! lol good luck sure it will be cake now
Old 06-28-2009, 04:40 PM   #7 (permalink)
Pry from above the vents which are part of the radio door with a smooth tool. I use a Snapon pin removal tool. And the radio door assembly will come off. If you have an Ap2 you will need to remove the center console first
Old 06-28-2009, 04:40 PM   #8 (permalink)
RL1924
RL1924's Avatar
I have ap2 and didn't have to take the cent off
Old 06-28-2009, 04:42 PM   #9 (permalink)
J'sS2K
J'sS2K's Avatar
1. You need to remove the shift knob.
2. And remove the center arm rest. The whole piece has to come off. There are 6 clips holding it down. Carefully pull it up.
3. And carefully pull the radio door assembly out.
The screws are exposed after you remove the radio door assembly.
www.getgopod.com
Old 06-28-2009, 05:45 PM   #10 (permalink)
Roger_Rabbit
So what about the little spring latch thing (circled in blue)... Anyone know where to get one of those?
Old 06-28-2009, 05:49 PM   #11 (permalink)
RL1924
RL1924's Avatar
Why did yours break?
Old 06-28-2009, 05:59 PM   #12 (permalink)
Roger_Rabbit
Yep... Was broken When I got the car... Drives me nuts... I will close it, hit a bump and it opens back up...
Old 06-28-2009, 06:05 PM   #13 (permalink)
RL1924
RL1924's Avatar
hmmm you would prob have to look on hondas parts thing but thats a tricky one such a small part
Old 06-28-2009, 06:43 PM   #14 (permalink)
There several different center consoles and some interfere with removing the radio door. On 2004 cars for instance.
Old 06-28-2009, 06:49 PM   #15 (permalink)
RL1924
RL1924's Avatar
04-09 are all the same no.. and mine is an 04, not trying to argue, just my personal exp didnt have to thats all
Old 06-28-2009, 07:45 PM   #16 (permalink)
J'sS2K
J'sS2K's Avatar
I think he meant the center arm rest piece...not the center glove compartment.
www.getgopod.com
Old 06-28-2009, 07:55 PM   #17 (permalink)
RL1924
RL1924's Avatar
I dont follow... around the shift knob area were talking about correct? I know ap1 to ap2 changed but dont think the shaped changed in any of the ap2's think they moved the defrost button but thats about it...
Old 06-28-2009, 09:30 PM   #18 (permalink)
J'sS2K
J'sS2K's Avatar
Yes you need to pull that off in order to get the radio door assembly out on AP2.
www.getgopod.com
Old 06-29-2009, 12:26 AM   #19 (permalink)
Roger_Rabbit
I got the radio out and the new one in... It will be going back to the store though... It does not filt good enough to get the radio door closed right... I only had to take out the plastic surrounding the stereo... I did not have to remove the shifter knob or anything in that area... I still need that little latch thingy ma jig... I will be purchasing another radio in hopes of getting a better fit... Has anyone ever installed one of those DVD playes that has the screen that hides in th head unit? Do they fit?
Old 06-29-2009, 06:55 AM   #20 (permalink)
RL1924
RL1924's Avatar
[quote=J'sS2K;96447]Yes you need to pull that off in order to get the radio door assembly out on AP2.[/QUOTE
Like I said to him though... I took mine off without doing that no prob and I have 04 ap2...
Old 06-29-2009, 06:56 AM   #21 (permalink)
RL1924
RL1924's Avatar
Problem with the pop out units is that it will be right in front of the vents, and when it comes out it comes straight out before flipping up probably would hit the shift knob, I have seen guys do custom fits for double dins where thats just the big screen molded into dashes and radio area but never the flip out one, dont think it will work.
Old 07-06-2009, 08:34 AM   #22 (permalink)
takeshi
takeshi's Avatar
Did you buy yours new directly from Honda? It's entirely possible that you have an AP1-style center console if you didn't have to remove it.
Old 07-25-2009, 10:28 AM   #23 (permalink)
Roger_Rabbit
I am on my 3rd stereo attempt... And it is successful... I got the newest El Kameleon from JVC... It is beautiful... The door does not close with the face in, but I will work on that... Thanks for all the help...
Old 07-25-2009, 01:20 PM   #24 (permalink)
RL1924
RL1924's Avatar
Not to be rude, but I do know the difference between the two I have ap2..
I did not have to take it out at all. All you have to do is start from the top and then pull it out thats where the clips are. Maybe some cant do it but its 100% possible and I thought pretty simple and straight forward
Old 08-18-2009, 01:49 AM   #25 (permalink)
tamay_s2k
go to honda and just ask for it. mine was broken and i brought a new 1 from honda. cost me $7
tamay_s2k is offline   Reply With Quote
Old 08-18-2009, 12:19 PM   #26 (permalink)
Roger_Rabbit
I appreciate it... You wouldnt happen to know the part number or know what its called would you?
Old 08-18-2009, 12:21 PM   #27 (permalink)
Roger_Rabbit
It was super easy... Just like you said... I only had to take out the radio bezel....
05, ap2, center, console, door, harness, honda, installation, radio, recommended, removal, remove, removing, replacement, s2000, stereo
