Go Back   S2000 Forums > Honda S2000 Forums > News & Special Announcements
News & Special Announcements Keep up to date about all on S2000.COM...
Old 07-19-2007, 04:29 AM   #1 (permalink)
anger
Question which oil
i have had my s2k for a year now(2006 model, bought in sept 2006), and i am tired of going to the dealer for the oil changes mostly because they keep forgetting to reset the oil life gauge. They have done it both times(7400mi), so, i have lost faith in them over something very simple( i.e. very sad day), I have only had 2 oil changes, and i need something to change
Here are my questions:
1) What do you guys think of synthetic vs. regular oil, I would like to go with royal purple, because it is what I went with in my last car, as well as that prolong crap(hey it really works).
2) Should i keep having the dealer do it their way or remove them from the situation totally and find my own mechanic( if so then can someone recommend one to me in chula vista, or san diego)
3) Does anyone know if that tornado fuel saver works? You guys know the little metal thing that is supposed to save you gas by creating a little compression/tornado in your air intake to pack more oxygen into the combustion.
anger is offline   Reply With Quote
Old 07-19-2007, 05:03 AM   #2 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
I am partial to Mobil 1 10W30.
Do your own. It's not that hard and you know its done right.
Don't waste your time and money.
Old 07-19-2007, 05:12 AM   #3 (permalink)
Grumpy old(er) phart
You are at the point where you can (and probably should) switch to synthetic. A lot of people use Mobil 1 10w-30. I use Redline 20w-50 but as long as Royal Purple meets the API requirements, you should be good to go.
Find a dealer you can trust or look for a good local mechanic. Buy Honda oil filters by the case from hondaautomotiveparts.com or handa-accessories.com (they cost less and you're using the recommended part and make sure you get the proper gasket as well). As long as the oil is changed according to the scheduled maintenance or when the idiot light says it's time, you shouldn't have any warranty problems.
It works to make money for the people who sell it to you. It doesn't do anything for the car. If it worked, it would be installed on every car in the universe. The only quick and easy fix to get better gas mileage is at the end of your right leg...
Old 07-19-2007, 08:12 AM   #4 (permalink)
Okay, so you're wonderin' if you can do as good a job'a changin' Stewie's life-blood as the dealer? Well, if you know which way tightens n' loosens most open-n'-close valves, nuts n' bolts, if you can properly locate a pan to compensate for the initial spurt of the oil and the follow-the-lowest-point'a-the-pan to drip somewhere else, n' you can read a dipstick . . I'd hafta say yes, you can.
As for oil, everybody's got their own preferences, but keep in mind: although we do tend to get a wee bit carried away with Stewie's exclusivity . . it's still a @*#&in' Honda. N' as such it's a pretty reliable piece'a machinery that isn't gonna puke it's guts at the first sign of non-five-dollar-a-can oil. Any brand name oil with the manufacturer's suggested oil change schedule should see ya through.
N' about that "Tornado" thing . . I got this bridge for sale, see?
Whenever you start thinkin' in terms's stuff like the "Tornado", grab the keys, take Stewie in search'a some twisties (hopefully you were dressed at the start of this exercise). If you can be considerin' flim-flam come-ons like that, you n' Stewie're spendin' entirely too much time in the hangar.
Whudduyadoon still sittin' there??????
Old 07-19-2007, 12:14 PM   #5 (permalink)
I use Mobil1 10W30 myself.
Old 07-25-2007, 07:15 PM   #6 (permalink)
Jbeni96
Proud Member
Jbeni96's Avatar
I think it's a good idea to do the oil change ourselves. I have a couple of questions regarding to the oil change. My cars is at 11, 500 miles and an idiot light has not come on. According to the manual the oil change is due at 11,250. Should I have the oil changed anyway?
The second question is - If i change the oil myself, how do I reset the oil life gauge, so that the light comes on at the right time?
Thanks,
JB
Old 09-17-2007, 09:50 PM   #7 (permalink)
philiam
Consider that Mobil 1 comes as a factory fill for Porsche, Corvette, Bay M Vay etc. The manual should tell you how to reset the service light.
Old 09-18-2007, 06:59 AM   #8 (permalink)
controller
Yellow is the fastest.
I like Mobil 1 non-synthetic. Changed regularly at every 3k miles. It goes further than just being able to tighten or loosen a nut when changing oil. To me, the biggest question is: do you feel comfortable getting under a car?
If you do, then invest in a good hydraulic jack and some stands, and never get under a car unless it's properly on stands. I don't think Stewie's approach angle goes for ramps.
If this isn't in your comfort level, it's pretty easy to reset the light. I'd consider doing it after getting in the car after the oil change. Instructions are in the manual.
Tornado fuel saver is garbage, do not buy. Everyone else gave the right reasons.
To Jbeni96, I'd change the oil anyway. I'm a stickler for oil changes.
Old 09-18-2007, 02:50 PM   #9 (permalink)
Phil, Porsche n' others r' usin' Mobil 1 synthetic right oud'a the gate?
'Sounds like the rules r' changin'. (Or, more accurately: the rules changed n' as usual, I was otherwize occupied.)
No kiddin' eh?
Well 'at about shoots everything I thought I knew on the subject right in the kiester.
Do they do a pre-break-in at the factory on those units y'think?
Old 09-18-2007, 02:58 PM   #10 (permalink)
s2kman000
Cool
ok, i have done my research on this subject pritty extensivly and just recently. posted on s2ki.com (witch is international), from top scientists in the world that have the results for our spicific car back, #1 was AMS 10-30 synthetic, #2 was mobile1 10-30 synthetic, royal purple actully belive it or not did not get a good rating for our car altho it is a very good oil it isant for the s2, now i have royal purple in my car right now and i didnt find out all this info till after i did the oil change..... ive also found that the royal purple burns when in vtec alot faster then my previous oils have, so ive had to add some here and there. i wouldant recommend changeing to synthetic till at least 10000. and for the guy that needs to kno how to turrn the light off.....hold down the TRIP button, insert your key turn on ignition, keep the button held down for at least 10 sec and you should see it turn off.
s2kman000 is offline   Reply With Quote
Old 09-18-2007, 03:12 PM   #11 (permalink)
s2kman000
oh and JBENI96, remember this, if you dont change your oil enough....it will always hurt you, if you change it to much it can never hurt you. if your not sure......do it anyways. thats a quote from one of my old instructors at automotive school who had his doctorate degree in automotive engineering and not to mention he's been around since the beganing of time.
Old 09-18-2007, 03:59 PM   #12 (permalink)
Ams oil is no doubt awesome oil. I use mobil 1 full synthetic cause ams oil is exspensive as hell and I dont think its that much better than mobil 1.
Old 09-18-2007, 05:56 PM   #13 (permalink)
philiam
Smile
No kiddin' eh?
Unless there has been a recent change. They have been doing it for years.
I read an SAE paper on oil tests, about 25/30 yrs. ago which claimed Mobil 1at 20,000 miles was equal to other oils at 7500. Dunno about pre-break-in but tolerances are much closer these days. Course I'm a dinosaur and things change.
Also heard some companies put Bars-leak in at the factory.
Old 09-18-2007, 06:15 PM   #14 (permalink)
philiam
You might find this site interesting.
http://www.bobistheoilguy.com/
Old 12-09-2007, 01:57 PM   #15 (permalink)
Jadranko
honda man
Jadranko's Avatar
i use mobil one extended life which potects for 15 000 miles.
Jadranko is offline   Reply With Quote
Old 02-12-2008, 01:52 PM   #16 (permalink)
ronnuke
I have used Amsoil 10W30 Full Synthetic since the second oil change at 14000 miles on my '04. It may cost a little more per quart but I call it cheap insurance for the way I drive mine like I hate it all the time. It gives me peace of mind that my engine and bearings are protected no matter how I punish them up to 10000 miles (my current change interval) with absoultely no ill effects. I am getting about 27.5 MPG too. My $0.02 YMMV
ronnuke is offline   Reply With Quote
Old 04-10-2008, 05:29 PM   #17 (permalink)
4406pack
cone destroyer
4406pack's Avatar
i use Mobil 1 10w 30 myself
Old 04-10-2008, 06:39 PM   #18 (permalink)
Blackdragon
[黒竜]
Blackdragon's Avatar
Send a message via MSN to Blackdragon
I use Castrol synthetic myself, but if your not castrol your mobil.
Blackdragon is offline   Reply With Quote
Old 05-01-2008, 02:26 PM   #19 (permalink)
uneekvisions
uneekvisions's Avatar
Send a message via AIM to uneekvisions
Exclamation
You don't actually wait that long to change your oil do you?!
2005 Silverstone AP2
uneekvisions is offline   Reply With Quote
Old 05-01-2008, 02:40 PM   #20 (permalink)
DJJSR
DJJSR's Avatar
Talking oil is like talking politics or religion. The discussion goes on forever and everyone still has their own ideas about it. I figure the Honda engineers know more about this car than any of us, so if they recommended putting cowflop in the engine, I'd grab a shovel.
Don
Old 05-01-2008, 07:27 PM   #21 (permalink)
chazdawg35
chazdawg35's Avatar
Hey Dudes! MOBIL 1 10w30 is workin' bitchin.K&N oil filter and magnetic drain plug are cool too.
Old 05-01-2008, 08:43 PM   #22 (permalink)
Can you start right off with synthetic cowflop'r dooya godda runn'er with dino cowflop ta break'er in first Don?
Old 05-01-2008, 09:52 PM   #23 (permalink)
s2k 4 me
s2k 4 me's Avatar
Mobil 1 and do it yourself. Takes less than an hour easily
04' NFR-Comptech - Veilside - Rick's - Fujita - Grillcraft - Tein - NRG - Berk - Chargespeed - Lucid - Carbing - Megan - T1R - Alpine - Boston Acoustics
Old 05-02-2008, 08:26 AM   #24 (permalink)
Pablo
Sentient Being
Pablo's Avatar
A DIY job for sure S2k. I've been changing my own oil in all manner of 2 and 4 wheeled vehicles for 40 or so years and none has been easier than the "S". Unlike most cars, you don't even get oil dripping down your arm when you unscrew the filter!
Regards,
Pablo
Old 05-02-2008, 09:00 AM   #25 (permalink)
"You don't even get oil drippin' down your arm"
'Sorry Pab. If there ain't oil drippin' down yer arm n' all'a other liddle oil-changin' delights . . have you really changed your oil?
('S'okay though. I still keep tryin''a sneak up on the refrigerator light ta see if it really goes out.)
Old 05-02-2008, 09:27 AM   #26 (permalink)
Swingle1
Gotta break 'er in first. So says the May issue of Bull & Shovel.
