Go Back   S2000 Forums > Honda S2000 Forums > News & Special Announcements
News & Special Announcements Keep up to date about all on S2000.COM...
Old 07-24-2007, 09:33 PM   #1 (permalink)
Jbeni96
Proud Member
Jbeni96's Avatar
noisy brakes
I realize that the S2000 is a sports car, which I love, but with that you give up some silence and comfort. Is it normal for a 2005 S2000 to have noisy brakes? It's not the screaching sound that you get when you need new brakes, but more of a grinding sound. I really appreciate your input.
Old 07-24-2007, 09:42 PM   #2 (permalink)
Vezna31
Vezna31's Avatar
How many miles on the car and the current set of pads? Grinding noise from front or rear? Is it felt in the pedal? OEM pads or aftermarket? Do you have stock wheels on the car? The only time I get noise is when I start the car for the first time and am backing out of my garage. Otherwise, no noise.
http://www.vezna.com
Old 07-24-2007, 09:59 PM   #3 (permalink)
Jbeni96
Proud Member
Jbeni96's Avatar
Vezna,
Thanks for your response. My car has 11,000 miles. I can feel the grinding on the pedal, and can also hear it. It has stock pads, but after market wheels. Is this normal?
jbeni
Old 07-24-2007, 10:23 PM   #4 (permalink)
Any chance that this goes away after a little use, as in the brakes wipin' the rust (caused by wet/damp weather) off the rotors? (Although I've never known that bein' so intense as to cause feed-back through the brake pedal)
Old 07-24-2007, 10:55 PM   #5 (permalink)
Vezna31
Vezna31's Avatar
Do you take the car to the racetrack? 11k miles could be warped rotors. Are you running the correct wheel offset? Incorrect offset can lead to more wear on the wheel bearing, but 11k miles seems pretty low for that unless you're tracking the car a ton.
Old 07-24-2007, 10:59 PM   #6 (permalink)
I would have the pads checked. The OEM pads have a wear indicator on them that will make a grinding sound when your pads are too low. Changing the pads will make the noise stop.
Old 07-24-2007, 11:03 PM   #7 (permalink)
Vezna31
Vezna31's Avatar
But unless he's terribly hard on the brakes, 11k miles is very low. I got 85k miles out of my 2 sets of OEM pads which also included 4 track days.
Old 07-25-2007, 07:06 PM   #8 (permalink)
Jbeni96
Proud Member
Jbeni96's Avatar
Noisy Brakes
I really appreciate all the feedback. I don't take the car to the track, but I'm not the original owner, so I don't know the whole history of this vehicle.
I will have the pads checked.
JB
brakes, braking, car, damp, forum, grind, long, low, noisy, offset, rotors, s2000, warped, weather, wet, wheels
Rear brakes lock up K0y0t3 All Other Honda S2000 Related Discussions 15 05-19-2009 09:23 PM
just did my brakes HELL_ON_WHEELS Wheels / Tires / Suspension 16 12-14-2006 01:38 PM
UK S2000 Disk Brakes Rotten! hatters All Other Honda S2000 Related Discussions 11 06-25-2005 07:01 AM
