Old 05-27-2008, 02:45 PM   #1 (permalink)
esparkey
FLAT TOWING
I own a motor home and a 2004 s2000. I would like to flat tow the s2000 behind the RV. Does anyone know if flat towing will do damage to the drive train?
Thank you
esparkey is offline   Reply With Quote
Old 05-27-2008, 03:09 PM   #2 (permalink)
Grumpy old(er) phart
Generally when you flat tow a rear wheel drive vehicle a lengthy distance, the drive shaft is disconnected. This does two things...it keeps the transmission from being constantly exercised and it keeps you from adding mileage to your odometer...(buy or rent a 2 wheel tow from U-Haul and tow the S2000 by the rear wheels...lock the steering wheel with the wheels straight..(how in the world with diesel at $5/gal and motorhomes getting about 3 mpg can anyone go anywhere in a motorhome? Just asking, you know... )
