Need help, car battery? not starting
Hey guys, i hope someone can help me with this situation. I baught a 94 civic so I can drive it to the ground instead of my S2k. The second day, I had to jump the car. So this is whats going on...
I jump start the car using jumper cables, then take off the cables. The car is running fine, since the alternator is running it. After or revving it for a long time, I turn the car off. The same second I try to start the car again, no power. and the light inside the car is very very dim, like low power. So i have to jump it again to start it. I took the battery out, thinkign its that to battery station here in Sun Valley, and they checked the battery, and it was fine. It can't be the alternator because the car runs without the cables connected. What else do you guys think it could be? Fuse? Relay? ehhh, its a messy headache |
Since the car starts using jumper cables, I doubt that there's a problem with anything other than the battery or connections at the battery. Be sure the connections are clean and tight, then put a charger on it for a while. A battery can test good, meaning it doesn't have a bad cell, but it simply doesn't have enough voltage.
Don |
