s2k4life
Launch question..
Hey guys I just got an S2k a few weeks ago and was wondering what the best way to launch the car is? Thanks
Off the top of my head I say forward is probably your best option
Village Pyro
the jokes may start up man. Reason why is launching this car isnt really what this car is built for. Its not a drag car, its a track car. You launch you might be replacing the diff.
Rev to about 4500 and hold it. Then when the light turns green let the clutch out quickly but not all the way. Ride the clutch just to make it hook then stomp it. This whole process should happen in under 2 sec. Don't ride the clutch too long or you will burn it up.
GO FAST OR GO HOME
#5 (permalink) | |
Village Pyro
I've seen a guy's video launching in VTEC. It sounded pretty cool, but I wouldn't recommend it or try it myself. The S2000's rear differential is a weak spot. SoundMan has already mentioned it
I forgot to metion that AP2 has CDV. It'll save your differential from a hard launch, but not good for the clutch!
Village Pyro
CDV=Clutch Delay Valve correct J?
That's correct SM
GO FAST OR GO HOME
I prefer a trebuchet, but you can use to big oak trees and a giant rubber band......
regards, jagg |
Click this link and scroll down a little, flawless launch technique.........
http://www.utubevideoclip.com/videos...s/Car_Catapult
Don |
Great video there Don, good to see the rich Lords have more to do than fox hunting.
cone destroyer
Dont you need a dry dock to launch, oh wait a minute, that is just for boats..
Senior Newbie
Landed on the wheels! That was awesome, I hope to have that much time someday...
#16 (permalink) |
s2k4life
Thanks for the info guys. I don't plan on doing it often, but just wanted to know, when I finally decide to take it to the strip.
#17 (permalink) |
Village Pyro
cool man good luck and give us the low down when ya do.
#18 (permalink) |
i did launch my S at 6000rpm with stock rubber potenza on dry surface and i miss
control the clutch padel...BOOM..i burnt it which was stock as well..smell it in the spot
123gogogo... |
#19 (permalink) | |
Car Dummy
If you are not running street tires (slicks, drag radials, etc.) then the it's a whole different ball park. If you dump the clutch at a high RPM, they will likely grab, get traction, and put LOTS of stress on the differential, likely breaking an OEM differential housing. |
#20 (permalink) | |
| burnt, differential, fastest, honda, launch, launching, lunch, rear, revs, s2000, s2k, smell, smelly, street, technique |
