| Website / Forum Suggestions / Site Problems All suggestions, problems, and general inquiries about the s2000.com website are welcome ! |
S2000 Battery
The battery in my '02 S2000 will no longer hold a charge. Any recommendations on an upgraded version or is the stock Honda replacement
my best bet? |
Some people have switched over to the Optima Yellow Top, but it's debateable that it's any better than an OEM replacement.
If your battery is not dead, the problem might be your car alternator.
Unless you have some big ICE (in car entertainment), you probably won't need to upgrade to some expensive sort of battery. If all else fails, you can always push-start your car |
A battery's mostly a battery wolf. 'S'long's it's got the amps to match up to what mother Honda installed at the factory it should be able to do the job.
I'm not up-to-date on it, but if a replacement Honda battery's much more expensive than a name you trust that's readily available locally, I'd go with cheaper brand, but again, as long as it's up to the amps of the OEM unit. Be well. Java
Battery
You will want to get as many amps as will fit in. The s2000 has very high compression and will put more strain on the battery. Higher amps will make things easier on all the electrics the battery will last a little longer. I can let my Civic stand for months and it will fire up at the turn of a key. They last me 7 years. It's an 89.
I have an Optima red top in my Diesel motor home and it holds up well. Could use a few more amps, though, Really high compression. It is a sealed unit and you never have to add water. They have gotten rather pricey though. But they have a 3 year replacement warranty. Not pro rated.
Phil, the higher compression has the battery needin' max amps at start up, but is there call for the extra amps other than that?
(I ain't bustin' chops, I'm takin' notes.) Thanks. Java
Dont take notes on that java and I am bustin chops lol. Sure its 11 ta 1 but its also 2 or 2.2 liters lol. My buddies nova with a 383 stroker motor running either 12 or 12.5 ta 1 started up with a garbage little battery no problem. I would be willing to bet a tractor battery would have enough to start our cars.
I run a optima red top in my one car and I can not say enough good things about it. Works great plus it looks pretty.
I hear ya isu, but, outside'a longevity n' its keepin' on, keepin' on . . how else do ya actually judge one battery as better'n another.
Aaaay! I'm dyin' here isu! When'a we gonna get an "in-depth" on the Vortech????? Stop polishin' long enough to fill us in why don'cha. Be well. Java
Alright I like the red top because you never have to worry about the posts corroding. It has plenty of cranking amps and it holds a charge forever. I left my other car sit for 8 months when I did the motor and it started right up. My buddy has a gto that sat for a year and he has a air bag suspension that he always plays with and that battery took it really well. I have had my red top for 3 years now and I just like it. I am sure when the batter goes in the s I will buy a optima for it too.
batteries? most of 'em are pretty good nowadays. just don't get some brand NOBODY ever heard of........
nuff said on that. need details on how the hop-up-job feels on your wheels isu!!!! |
Some people have actually gone to a smaller battery to save weight. Personally, I would go with another OEM. Mine has lasted almost 6 years.
I'm trying to remember if I've ever changed my battery.
![]() As far as a battery to handle high compression, I would tend to disagree since the only thing the battery does is start the car. The alternator takes over after that.
#13 (permalink) | |
My stukay sure doesn't turn near as fast as my 90 Civic. I don't know if the battery has been replaced or not. The car is a very well maintained 2002. There are only about 3 companies that make all the batteries under different labels. But they are made to different specs.
wolfie.
you have a 2002 ap1 model, this is 2007. It is a 5 years old battery, thus it is possible your battery need a replacement. Go to an autoparts store and look for a replacement. Make sure to get a correct size for your car. It should be about 28 pounds in weight. Or you can experiment lighter weight battery like oddysey, spoon sport and buddy club. Also check your alternator by looking at the battery and brake warning lights, if they both appear at the same time. Have a shop inspect for alternator failure. |
If you're gonna pull you battery for some reason hook a battery charger or 9 volt battery to the cables before disconnecting and the radio will keep its code. Be sure to reconnect before taking the back up off.
#16 (permalink) | |
#17 (permalink) |
BTW - wrong forum. This is as the title suggests for posting about the actual website (eg coding/bugs etc).
#18 (permalink) |
If you are looking down the road to better performance one way to start is to buy a lighter battery that will do the job, there are several out there that will. when you add everything up it really makes a difference, It did in my car anyway.
#19 (permalink) |
S2000 battery
I bought my S2000 new, a little more than 7 years ago. I dont drive it a lot. It often sits for one or two months. It still has the origional battery. Although its starting to get weak, it always starts the car with ease.
I know its time to replace it so I compared prices and performance specks of other batterys and found that most top of the line brands cost considerably more than a Honda OEM battery. Even Odyssey only rates their reccomended PC925LMJT at 3 to 7 years of life, with only a 2-year warranty. You can find great prices on Honda batterys on line. But beware, they can't ship batterys. They are considered Haz-Mat. You will have to buy locally and there goes the great discount prices.I say stick with the Honda OEM and buy it at your local Honda dealer. It might cost a little more than a Wal-Mart special, but the quality is worth it. Use a quality battery charger that can desulfide the battery. I got more than seven (7) years out of mine.
#20 (permalink) |
Optima recently came out with a new D51 which is the size that fits our cars. And is different information than the last time I spoke to them. It is a yellow top and is superior in every way to standard flooded electrolyte batteries. When I need a new battery that will be my choice. And you don't need any more amps than it supplies. And it's lighter than the stock one
#21 (permalink) | |
#22 (permalink) |
Battery is a battery (if you are just using it for cranking a S2000),if you get OEM or anything close to it, it will be fine.
#23 (permalink) |
Dozens of times I've started a car with a flat battery by bumping it. If its gotta clutch them you can "bump" to start if you can't turn the car over !
#24 (permalink) |
Its a Honda. They start so quickly the battery doesn't have to work hard. My 89 Civic OEM lasted 7 years. Replaced it with a Kirkland (Costco) and that lasted 7 years. On my 2nd Kirkland and it still starts quickly after sitting for a month or more.
My 2002 S has the original battery and it still fires right up.
#25 (permalink) |
8 years and stil alive!
In a recent service, the Honda folks told me that my battery was only putting out 250 cca. It's supposed to be in the 400-470 range when performing like new. Here's the weird thing, my car turns over and starts just fine. I've never had an issue. I got my S2000 when they first came out as a 2000 model. It still has the original battery!
So I read with great interest the opinions of all the folks regarding the longevity of their OEM batteries. I think it really has more to do with the quality of the electrical system. I once had an older Ferrari that I put an Optima Red Top into. On several occasions it was DEAD and I had to jump the car. I had this start happening when the battery was less than a year old. So I think that the Italians just can't do electrical correctly. Honda has got that nailed. As for my S2000, I got one of those emergency booster packs and keep it in the trunk. I am determined to see how long and OEM battery will really last. When my car will no longer start, I'll use to booster pack to get me going to the nearest Honda dealer, when I will get another OEM battery! |
#26 (permalink) | |
| 2000, batteries, battery, braille, buy, charging, desulfiding, forum, honda, oem, optima, replacement, review, s2000, yellow |
| Braille Battery | Lonegunman | Interior / Audio / Electronics | 14 | 11-09-2007 09:32 PM |
| Battery Died Now Radio needs code | Cosmo | Interior / Audio / Electronics | 9 | 04-03-2007 08:45 AM |
| Installed intake, disabled battery, need radio code (electronic problem) | Elusive8S2k | Interior / Audio / Electronics | 6 | 02-10-2007 05:31 AM |
| Powercable from battery & into the car? | odderik | All Other Honda S2000 Related Discussions | 0 | 07-14-2004 05:15 AM |
