Old 12-25-2006, 05:38 PM   #1 (permalink)
Elusive8S2k
Upgrading wheels, what size/offset?
I have a 2003 S2000 and eventually wanted to upgrade the wheels and tires. I already have my idea for tires but on wheels, what size/offset should I get. I don't know anything about this car. Is 17" better than 18" and whichever one you help me decide on, what offset do I need to get because I know the front wheels are staggered from the rear wheels. I'm just not used to that. Thanks for any info.
Elusive8S2k is offline   Reply With Quote
Old 12-25-2006, 06:30 PM   #2 (permalink)
OEM 17's:
Front:
17" x 7.0", +55 offset, 215 tire
Rear:
17" x 8.5", +65 offset, 245 tire
My 18's:
18x8 +51 in front
18x9 +63 in rear.
Old 12-25-2006, 07:29 PM   #3 (permalink)
Elusive8S2k
Gomarlins3,
Thanks for the information. Do you possibly have a pic with the 18's on your car? Does it still ride nice? Thanks. Oh, and where did you order your wheels from?
Old 12-25-2006, 09:50 PM   #4 (permalink)
Elusive8S2k
And if anyone that reads this that has custom wheels on their S2k could please post pics, I'd really appreciate it. I'm looking for some ideas. Thanks.
Old 12-25-2006, 11:52 PM   #5 (permalink)
Bought them used on S2Ki.
Old 12-26-2006, 06:17 PM   #6 (permalink)
Elusive8S2k
Will the konig prophets work good? Anow now I'm stuck on which I should get. 17's or 18's
Old 12-28-2006, 05:56 PM   #7 (permalink)
Elusive8S2k
Ok, i found some. They are 18x8's in the front, and 18x8.5 rear. They both have offsets of 48mm. I am going with the falken ziex512 tires but need to know which size to get. Can anyone verify that these wheels will fit and which size tires would fit on the falken ziex 512 line? Thanks.
Old 12-29-2006, 04:42 PM   #8 (permalink)
Elusive8S2k
Ok, I guess I am right on this. I am getting 225/40/18 for front and 245/40/18 for the rear. Does that sound right?
Old 12-29-2006, 05:11 PM   #9 (permalink)
Elusive8S2k
Well crap, I keep confusing myself here. Now I went to another website that had fitments for an 03 s2000 and most of them were 215/40/18 for front and 225/40/18 for rear. The guy I talked to recommended 225/40 for front and 245/40 for rear. Which one do I use? UGH!!!!!!
Old 12-31-2006, 01:46 PM   #10 (permalink)
primm907
gomarlins3, do you have a drop on your s2000? If so, what did you utilize? I'm considering an s2000, and I'd like to get an idea of how much upgrades might run me. Also, does anyone have experience with the skunk2 lowering springs? They appear to offer a pretty aggressive drop (approx 2"); whereas, the Eibach Pro-Kit is only about 1"...thanks.
primm907 is offline   Reply With Quote
Old 01-06-2007, 10:13 PM   #11 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
Yea i had some skunk2 lowering springs on a 98 prelude 2" the dropped was good but the spring were too hard for me.I ended up putting the stock ones back on in about a week.I thought the spings was great if your only tracking.They are the only part that i know if that i would listen to the tag that says for off road use only.I dont remember if the box had that on it but it should.
Old 01-20-2007, 11:36 AM   #12 (permalink)
AGBLLET
I have the same wheels as GoMarlin3 but I think he paid less since I ordered mine from the factory. I like a clean look with a little lower profile appearance than than the stock so I lowered my S about 1" or so. I elected to replace my stock 17 and 17.5 wheels with 18" all around. The size rims I elected to go with was 18x8.0 +51 offset F and 18x9.0 +60 offset R. I believe that you will find that many of the newer model 18" wheels weigh the same or in some cases even lighter than the stock 17" wheels. They are not inexpensive however.
Since I only lowered my car by 1" or so, I elected for the following sizes of tires: 225/40-18 F and 255/35-18 R. I need a little wider rear tire and the enhanced grip since my engine generates over 400 rhp and the wider tire helps from swapping ends and we all know is a trait associated with our S2ks. The size wheels, tires and the lowering were coordinated to ensure that the car maintained its full perfomance and handling characteristics and no rubbing occurs during hard cornering.
Everyone has their own idea as to how they want their car to look. You want to be proud of its appearance but not degrade any of its performance or handling characteristics. In my humble opinion, my car is the best looking one around since it is silver instead of Black. Sorry Marlin, I could not resist that one! If you examine Marlin's car, you will notice that he may have lowered his car a ljust a tad more than 1", but the overall effect is the same in terms of achieving a more aggressive appearance but still understated to enhance the beauty of the car's design without overdoing it. Finally, whatever you decide, make sure that the overall fit stays within the stock specs for handling and avoid any set up that would make your tires rub during hard turns or over speed bumps.
Good luck.
AGBLLET is offline   Reply With Quote
Old 01-20-2007, 12:02 PM   #13 (permalink)
AGBLLET
I have the same wheels as GoMarlin3 but I think he paid less since I ordered mine from the factory. I like a clean look with a little lower profile appearance than than stock so I lowered my S about 1" or so. I elected to replace my stock 17 and 17.5 wheels with 18" all around. The size rims I elected to go with was 18x8.0 +51 offset F and 18x9.0 +60 offset R. I believe that you will find that many of the newer model 18" wheels weigh the same or in some cases even lighter than the stock 17" wheels. They are not inexpensive however.
Since I only lowered my car by 1" or so, I elected for the following sizes of tires: 225/40-18 F and 255/35-18 R. I need a little wider rear tire and the enhanced grip since my engine generates over 400 rhp and the wider tire helps from swapping ends and we all know is a trait associated with our S2ks. The size wheels, tires and the lowering were coordinated to ensure that the car maintained its full perfomance and handling characteristics and no rubbing occurs during hard cornering and driving over speed bumps/humps.
Everyone has their own idea as to how they want their car to look. You want to be proud of its appearance but not degrade any of its performance or handling characteristics. In my humble opinion, my car is the best looking one around since it is silver instead of Black. Sorry Marlin, I could not resist that one! If you examine Marlin's car, you will notice that he may have lowered his car a just a tad more than 1", but the overall effect is the same in terms of achieving a more aggressive appearance but still understated to enhance the beauty of the car's design without overdoing it. I only mention that since his offsets are just a tad higher than mine which would accomodate a lower profile suspension. Finally, whatever you decide, make sure that the overall system fit stays within the stock specs for perfoemance and handling and avoid any set up that would make your tires rub.
Good luck.
17, 18, aggressive, front, honda, number, offset, offsets, pictures, proper, rear, rims, s2000, size, wheel, wheels
18 inch wheels with 38 offset fit a 02 s2k???? twofast4u All Other Honda S2000 Related Discussions 11 04-09-2008 03:17 PM
Upgrading to Legend/NSX 2pot calipers Kalm_Traveler Wheels / Tires / Suspension 2 02-27-2008 07:54 AM
What wheel size do I need?? Punisher All Other Honda S2000 Related Discussions 0 04-03-2006 08:45 AM
2003 S2000 wheel size, offset. jkwynn All Other Honda S2000 Related Discussions 2 09-03-2005 01:10 PM
