Old 02-13-2007, 11:39 AM   #1 (permalink)
S2Killa
Send a message via AIM to S2Killa Send a message via Yahoo to S2Killa
sensitive steering or problem?
I've noticed that sometimes when I shift it's hard to keep the car completely straight and it wiggles some. My best friend and my brother have both driven it and they both noticed the same thing. They both thinkkk that there's a problem with the power steering. Any suggestions?
S2Killa is offline   Reply With Quote
Old 02-13-2007, 12:52 PM   #2 (permalink)
Aaay 'Killa, how ya been?
Stewie is very sensitive to input. No surprises there right? Unless you've managed to figure out some other way to shift n' drive, you're one-handin' the wheel while liftin' the weight of a leg to handle the pedal while you're shiftin'.
Add to that that most of us don't jus' throw gears with our right arms (or left arms dependin' on which side'a the pond we're on) we use our whole body to some extent.
As for your best friend n' your brother . . do they have any Stewie experience to gauge this by? If not, you're askin' folks unfamiliar with the car to make an assessment. Usually not the best thing to go by.
My money'd be on the car jus' bein' what we bought it for: very sensitive to input. Face it, you're not noticin' any of the symptoms durin' the 99% of your time in the cockpit when you're not shiftin', right?
Old 02-13-2007, 01:16 PM   #3 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
HEy killa i know what your talking about i'm no expert by no means but i have driven lots of cars. I think if you havent driven a car with a rear wheel drive LSD you couldnt tell the little differance in driven it.But what i think your talking about is normal.
I could tell what your talking about a few days after getting my car, Like when your under excel in a curve "not pushing it or racing" just under a nice excel and you let off you can also fill it pull to the direction of the curve.Correct me if i'm wrong someone but I think it has to do with the LSD being locked and when i let off the resistance between the inside tire and the road is released because under excel it is spining the same rotation as the outside tire but not traveling as far "in a curve"so there for it is scrubbing the ground but when i let off it releases. I hope i'm not sounding all retarted but i know with my truck i have a detroit locker rear end and it does some what this samething. I'm i out in left field? Or does this theory make any sense?
Old 02-13-2007, 02:10 PM   #4 (permalink)
sounds pretty normal to me the car is rwd. Get in a camaro or mustang and slam gears if ya wanna see some wiggle.
Old 02-13-2007, 02:23 PM   #5 (permalink)
Check your rear tire pressures. I am betting one is less that the other. If not, tell me and I will tell you the next thing to check.
Trust me.
Old 02-13-2007, 02:44 PM   #6 (permalink)
S2Killa
actually one is lower than the other I'm gettin it replaced in a couple days
Old 02-13-2007, 03:05 PM   #7 (permalink)
Told ya. Problem solved I'll bet.
Old 02-13-2007, 03:29 PM   #8 (permalink)
I can feel that smug look on your kisser from here Go.
Killa, what's the whole story? Jus' a guess, but I don't figure you're replacin' tires because the pressure is low. 'Sounds like we got extenuatin' circumstances.
But, if it was improper inflation . . . Go wuz right.
Old 02-14-2007, 10:50 AM   #9 (permalink)
S2Killa
well it has a hole in it. I got it plugged by it didn't help much so I just have to get it replaced. My brother and I thought that it was a small enough hole that we could just get it plugged and be ok but we were wrong.
Old 02-14-2007, 01:40 PM   #10 (permalink)
Tim Gedney
Send a message via AIM to Tim Gedney
Sensitive steering, to be sure...
Java has ID'd the issue exactly. When I'm shifting fast, I notice exactly the same thing, and it's nothing more than my left hand moving a bit when I'm pushing the stick forward. Wanna be gutsy? When it's safe and stable, ease your left hand/grip off the wheel for a sec while shifting. You'll see the problem has gone away.
Tire issues would be a constant...not just with shifting.
No worries!
Tim
Tim Gedney is offline   Reply With Quote
Old 03-07-2007, 11:31 PM   #11 (permalink)
BabyItsaFact
Questionable Standing
BabyItsaFact's Avatar
Hey, Bobby! What you are describing is probably due to weight shift as you let off the gas. The LSD shouldn't lock AT ALL under normal driving situations. To check if yours does, just turn the wheel all the way to the lock and drive in a circle. If your LSD locks, it'll feel like you're in 4-wheel drive trying to do donuts. The limited slip dif lets one wheel spin faster than the other and should only lock if one tire loses traction.
BabyItsaFact is offline   Reply With Quote
carsteeringsensitive, control, gas, honda, letting, power, problem, pulls, s2000, s2k, sensitive, steering, tilt, traction, wheel
steering wheel s2000 player Interior / Audio / Electronics 2 01-15-2007 09:40 PM
Steering wheel feel seems off RickR Wheels / Tires / Suspension 3 12-22-2006 12:44 PM
Steering box coxybabe All Other Honda S2000 Related Discussions 5 02-21-2006 10:30 PM
Tilt Steering? GrassMower All Other Honda S2000 Related Discussions 3 08-27-2004 12:20 PM
