Old 03-19-2007, 04:55 PM   #1 (permalink)
bjurasz
Dupli Color Caliper Paint
Anyone used Duplicolor Caliper Paint on any of their cars? I'm thinking red calipers for mine. I'm most curious about its ability to hold up to high heat caused by autocross or HPDE's. Thanks.
Old 03-19-2007, 09:07 PM   #2 (permalink)
It's specifically made for that in that it's a hi-temp paint BJ. My guess is that the folks at Duplicolor've been doin' this long enough where they wpuldn't be sellin' it for calipers if it wasn't capable of puttin' up with the heat incurred while the caliper's doin' what it supposed to do.
I'd thought about it myself, but, as the calipers do get heated up, the release of that heat is important. A coating of paint will only impede that heat release. (Okay, okay . . so I jus' don't wanna. After all, Ferrari paint's theirs, don't they?)
Old 04-12-2007, 12:47 AM   #3 (permalink)
WhiteKnight
I personally would rather pay the $45 or so and go have them powdercoated. IMO. I've used Hi-temp paint on some of my other cars and it does tend to wear off over time.
WhiteKnight is offline   Reply With Quote
Old 04-12-2007, 07:27 AM   #4 (permalink)
G2 is what I have always used.
Old 04-12-2007, 09:01 AM   #5 (permalink)
bjurasz
G2 - producer and distributor of the G2 BRAKE Caliper Paint System Set and other high quality carstyling and performance products. - looks like good stuff. Much higher max-temperature than the DuplicColor. I think I'll give that a try.
Old 04-12-2007, 02:55 PM   #6 (permalink)
satisaii
Send a message via AIM to satisaii
I have the G2, but burned it tracking the car. You won't have a problem on the streets with it.
satisaii is offline   Reply With Quote
Old 04-12-2007, 04:00 PM   #7 (permalink)
bjurasz
Good info guys! Thanks. For street and autocross use G2. For track days go for powder coat.
Old 04-12-2007, 06:40 PM   #8 (permalink)
The only time I have burned my G2 at the track is hen I didn't have enough pad in the caliper. All the other times I haven't had a problem.
2006, caliper, calipers, coating, duplicolor, durable, forum, g2, heat, honda, max, paint, red, s2000, temperature, wheel
Touch - Up paint ? danx337 Exterior / Detailing / Body Work 3 07-12-2007 01:05 PM
Spots on white paint Plinko Exterior / Detailing / Body Work 5 10-04-2006 07:13 PM
Paint Chipping on hood...is this common with all S2000s oldboyroy All Other Honda S2000 Related Discussions 6 03-28-2006 08:23 AM
paint code Anonymous All Other Honda S2000 Related Discussions 1 11-08-2003 10:02 PM
