Old 03-21-2007, 05:06 PM   #1 (permalink)
Dr. Jimbo
Top Always Down
Dr. Jimbo's Avatar
Change brake fluid?
I'm due for my 50k-ish service and the owners manual says to change the brake fluid. Never done it on any other car I've had (didn't know the stuff went bad). Should I do it or will my brakes give out on some steep, windy mountain road and I'll be forced to e-brake my way to a death defying stop. I figured you guys know best.
Thanks,
Jimbo
Old 03-21-2007, 05:56 PM   #2 (permalink)
batguano
Andiamo Veloce
batguano's Avatar
You can find answers to that and much more here.
Good luck.
S2000 Do-it-yourself mods & repairs - S2000 Atlanta
Old 03-21-2007, 06:09 PM   #3 (permalink)
No, your brakes will not stop working on you, but they will not work the way they are designed to. Changing the brake fluid is not that hard, but if you are not comfortable with the 'press and hold' method, take it to a professional. Just a reminder, the S is not bleed like normal cars where you start at the furthest caliper from the reservoir and work your way closer. You start at the closest and work your way away. I am not sure why this is, but I have read about it at S2Ki and also in the Helm's manual.
Old 03-21-2007, 06:11 PM   #4 (permalink)
Dr. Jimbo
Top Always Down
Dr. Jimbo's Avatar
WOW! Great link. I'll go there before I ask any dumb questions. Us forum newbies sometimes ask redundant questions and you guys that have been around the block a few times probably get tired of answering the same stuff over & over. I try to locate answers before posting a question, but my forum navigation skills are still in their infancy.
I clcked on "manually changing the brake fluid" and it said "not found." Bummer. I guess it's just best to get'r done.
Thanks,
Jimbo
Old 03-21-2007, 06:35 PM   #5 (permalink)
bjurasz
I first used these ten years ago when doing HPDE's in a Corvette. Changing the brake fluid before every event, 5-6 times a year, got old. This makes it very easy:
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
I now have them on my Mazda Tribute and soon to install on my S2K. You'll want part numbers SB10125 front and rear.
Brake fluid absorbs water, even humidity from the air. Past seals, from the resevoir, etc. That is one thing that makes it go bad. Heat is the other, and brakes generate a lot of heat (its their job to turn the motion energy of the car into heat energy, thus stopping the vehicle).
Old 03-22-2007, 11:09 AM   #6 (permalink)
Dr. Jimbo
Top Always Down
Dr. Jimbo's Avatar
Thanks, you answered my question about the stopping juice. So it actually does go bad, the fact that brake fluid is a hydrophilic liquid. Another mystery solved.
bleeding, brake, brakes, break, change, changing, clutch, definition, fluid, honda, interval, replace, replacement, s2000, s2ki
Stock Brake Life bladerunner Wheels / Tires / Suspension 9 04-29-2007 11:34 AM
Engine oil & Tranny fluid cpiercecf Engine Tech / Drivetrain 11 04-27-2007 10:26 AM
Gear brake or not wowowox All Other Honda S2000 Related Discussions 6 02-19-2006 12:09 AM
Brake Upgrade Leebo All Other Honda S2000 Related Discussions 4 10-20-2005 09:50 AM
Brake question? DM1 All Other Honda S2000 Related Discussions 1 09-02-2005 05:50 PM
