Old 03-25-2007, 11:36 PM   #1 (permalink)
bjurasz
Alternate Lift Locations
I know of the four factory recommended jack locations. Problem is, you put the floor jack there and now you can't put a jack stand in the same place. So I'm looking for alternate lift locations. Ultimate goal is getting four jack stands under the car and all four tires off. I envision lifting two tires at a time and placing two jack stands at a time. Where do you guys lift to do this? Thanks.
Old 03-26-2007, 10:13 AM   #2 (permalink)
When I am lifting the front, I use the jack on the jack points and put the stands where the back of the lower "A" arm meets the frame. When I am jacking the back, like now, I use the jack on the jack points and place the stands under the two tubes (frame) in the rear.
2000, floor, honda, jack, jacking, jackstands, lift, locations, place, point, points, put, s2000, stand, stands
VIN Locations? CrazyAZ All Other Honda S2000 Related Discussions 1 01-06-2007 09:35 AM
