Old 05-05-2007, 10:23 PM   #1 (permalink)
leo520
Cool 18 fotment for my 07
Looking for a set of SSR Professor SP1 Color Finish=Black+Lip.
size 18x 7.5 front 18x9.0 rear.
I'm wondering if these will fit on my 07 AP2 without fender rolling and camber by lowering my car in about 1 or 1.5 front and rear? ANY response and help would be more than appreciated.
Thanks
Old 05-08-2007, 12:53 PM   #2 (permalink)
carguy123
carguy123's Avatar
What is their offset? That's what determines how they will fit.
I am running 18" and my rims are the Kinesis k58 - 18x7.5 front 53mm offset and 18x9.5 73mm offset rear
Tires are S02s
Front = BMW spec 235/40 X18 = 9.2” wide
Rear = Porsche N2 spec 265/35 X18 = 11.1” wide
I am running JIC coilovers with about a 1.25" drop and I have no rubbing. I did roll the back fenders to be safe.
carguy123 is offline   Reply With Quote
Old 05-10-2007, 08:09 PM   #3 (permalink)
Scott
Scott's Avatar
Yep, depends on your offset. But it's probably going to be a tight fit if you don't want to roll the fenders any.
1966 Ford Mustang
2003 Land Rover Freelander
Old 05-10-2007, 08:18 PM   #4 (permalink)
leo520
damn really???
Old 05-10-2007, 08:53 PM   #5 (permalink)
Scott
Scott's Avatar
Unless you nail the offset spot on, it's probably possible to do without rolling the fenders if you:
A. Run a seriously stretched low profile tire, which will be fairly unsafe.
B. Run a very stiff suspension with as little travel as possible.
1966 Ford Mustang
Old 05-11-2007, 12:14 AM   #6 (permalink)
leo520
so what kind and what size and off set of wheel do u suggest ,if i will like the size of 7.5 front 9.0 rear??
k58, kinesis, professor, s2000, sp1
