I recently bought a 03 with 04 17" rims. The car sits higher on one side (about 1/4"). I asked the members about it and it was suggested that it could be tire pressure or bad tires. So off I go into the garage and bam there it is. The right rear tire had been replaced with another brand (same measurements). I have the tire replaced and the problem is still there. the car rides higher on the right side and pulls when I accelerate could this all be an alighnment issue? Any suggestions are greatly appreciated.
Possibly, but I doubt it. I think you have two different problems there. As for the ride height being different, assuming you are still on the OEM suspension, my guess is the spring rubber is still in one of the springs and needs to be removed.
As for the pulling to one side upon acceleration (I am also assuming it goes the other way when you decelerate/release the gas), you now have two different tires that have been worn differently (now have different circumferences) and thus you car pulls one way or the other. You will need to get matching tires with the same PSI's to get it solved.
#3 (permalink) | |
Thanks |
Raconteur
When the car is shipped, a piece of dense rubber is inserted in the spring coils for shipping. About 90% of the dealers remove the rubber pieces before the car is delivered to the first buyer..the other 10% don't even know it's there (I think this is what gm is talking about). You can check by looking at the coil springs and seeing if there is something stuck in the coils. There shouldn't be anything there but spring...
#5 (permalink) | |
#6 (permalink) | |
Raconteur
(if you have trouble following the above link, try this: Forums -> Look what I found in RhinoS2K's car! (A NEW WORLD RECORD!) ) |
#7 (permalink) | |
I checked the springs and I don't see any rubbers. Everything looks normal as far as I can tell. I adjusted the tire pressure and it helped a bit but the pulling is still there and the ride height is still visible. The car was a theft recovery and I'm beginning to think that the car was stripped and ditched possibly sitting without wheels on one side for a period of time. That may have damaged or weakend the spring on that side. It only had 3500 miles when I got it and the only mod is the 04 rims and rubber.
JAC, unless you do the deed n' put a known set'a matched hoops on the car, you're never gonna know. N' you're talkin' about the actual source'a traction here. what? 'Cause it's gonna cost ya some you're gonna hold back on puttin' a good set'a sneakers on your ride?
We ain't talkin' some shiny piece'a unobtainium for discussion when you're sittin' 'roun' bench racin'. We're talkin' what keeps your posterior oud'a the landscape when you're powerin' through a turn. Stop hemmin' n' hawin' JAC. Stewie needs a new pair'a shoes! Be well. Java
#10 (permalink) | |
'S'okay JAC. I even confuse myself sometimes.
Be well. Java
| 01, accelerating, car, coil, height, heights, honda, limit, pulls, rear, replace, ride, s2000, springs, stock, uneven |
| 5 foot tall driver? OK Car for someone of this height? | lookin | All Other Honda S2000 Related Discussions | 5 | 06-02-2006 12:17 AM |
| Getting used to the Ride....need help please | mistysf | All Other Honda S2000 Related Discussions | 20 | 10-11-2005 01:45 AM |
| Need advise?!? uneven suspension height | theartfanatic | All Other Honda S2000 Related Discussions | 5 | 07-25-2005 11:26 AM |
| LOOKIN FOR A SEXY RIDE!!! | Stephanie | All Other Honda S2000 Related Discussions | 8 | 06-18-2004 11:44 PM |
