Old 09-30-2007, 10:15 PM   #1 (permalink)
Tee-Dub
Tee-Dub's Avatar
Question Tein S-tech springs and alignment
Starting to look at mods and figured I'd start with the simple, suspension. I've ruled out coilovers due to expense and the fact that I don't need adjustable height. If I install the Tein S-tech coils, will a camber kit be required or can a reputable alignment shop get her in spec with the factory adjustments?
Any benefit to coil overs besides the adjustability issue?
Tee-Dub is offline   Reply With Quote
Old 10-13-2009, 11:23 PM   #2 (permalink)
reagd
Originally Posted by Tee-Dub View Post
Starting to look at mods and figured I'd start with the simple, suspension. I've ruled out moog coil springs due to expense and the fact that I don't need adjustable height. If I install the Tein S-tech coils, will a camber kit be required or can a reputable alignment shop get her in spec with the factory adjustments?
Is that so? Can you tell me or please elaborate why should I disregard the coilovers on this matter? Thanks.
reagd is offline   Reply With Quote
Old 10-14-2009, 12:55 PM   #3 (permalink)
JOECHY
JOECHY's Avatar
Your question isn't that clear. Can you be more specific?
2007, alignment, forum, honda, instal, install, installing, proper, s2000, springs, stech, stechs, suspension, tech, techs, tein
