Old 01-10-2008, 06:16 PM   #1 (permalink)
stevet
Spare tire, what for?
According to the manual, using the spare tire on the rear will trash the diff. I think I have also read that the spare has been dropped in 2007 or 2008 and replaced with a can of inflator/ sealer. Any thoughts on removing the spare to make a little more luggage space?
stevet is offline   Reply With Quote
Old 01-10-2008, 06:28 PM   #2 (permalink)
Raconteur
I don't have one...just a can of Fix-A-Flat and a empty tool tray where the jack and other miscellaneous stuff used to live in the trunk...saves about 30 lbs over all...
Old 01-10-2008, 06:41 PM   #3 (permalink)
Neil
Neil's Avatar
My 2007 has a spare, but the CR does not. It has the inflation can
Old 01-10-2008, 06:42 PM   #4 (permalink)
DJJSR
DJJSR's Avatar
If you have a flat rear tire, I think you're supposed to move a front tire to the rear and put the spare on the front. Did I read that somewhere or did I make it up?
CAUTION - If you use that fix-a-flat, tell the tire shop it's in there!
Don
Old 01-10-2008, 06:52 PM   #5 (permalink)
Yes, you are suppose to place the front tire on the rear and the space saver on the front.
I carry the tools unless I am going to the track. Then I have my race tools/equipment in the trailer so I take the tools out of the trunk and use the space for luggage. I still carry the spare because I do not want to use a race tire as a spare if I have a flat unless I ABSOLUTELY have to.
Old 01-10-2008, 07:10 PM   #6 (permalink)
Old school, n' still carryin' the spare n' all the goodies.
But on the bikes I've carried a can'a fix-a-flat fer years. You've got the ol' guy considerin'.
But they've also got some great plug kits that I've also used for alodda years n' swear by. Maybe jus' the kit n' a can'a compressed air for inflation once it's plugged.
'Gonna godda think on this fer a spell.
Be well,
Old 01-10-2008, 07:26 PM   #7 (permalink)
Pablo
Sentient Being
Pablo's Avatar
WOW, I'm glad I read this post.......I musta missed that page in Mother's Manual. No doughnut on the rear huh........well, that is interesting.......
Thanks and regards
Pablo
Regards,
Pablo
Old 01-10-2008, 08:18 PM   #8 (permalink)
Okay, smoke's cleared.
I'm plumb scared'a there bein' witnesses fer some yayhoo lyin' dead in'a road alongside'izz flatbed that he was usin' ta scrape body parts off my Stewie.
I'm gonna opt ta remain carryin' the spare, the changin' goodies, the very amazin' n' capable plug kit n' a can'a Fix-a-Flat.
I jus' like havin' options.
Fix-a-Flat'z okay'z a last resort, but I worked on the other side'a the counter in tire shops n' I still do my own tire work. Didn't like dealin' with it then n' I don't seem ta be gettin' any more tolerant'z the clock goes tickin' on it's merry @*#&in' way . . . y'know?
Be well,
Old 01-11-2008, 02:42 PM   #9 (permalink)
stevet
Thanks for all your comments, I really appreciate the input. I think I'll stay with the spare also. Can't help wonder why the spare would hurt the diff though. It should be the made to be the same ride height. It's not an experiment I want to try so I'll take the Honda Engineers word for it.
Steve
Old 01-11-2008, 03:20 PM   #10 (permalink)
I'd think that it's probably more about the traction difference that'd be involved with the extreme difference in rubber compound n' patch Steve.
Old 01-11-2008, 05:47 PM   #11 (permalink)
My theory (and it's only a theory) is that I believe the diameter of the OEM rears and the donut are different. The diff would want to lock up constantly because of the difference in rotations.
Old 01-11-2008, 06:08 PM   #12 (permalink)
GM3's on the money guys.
Damage would likely occur if the rear tires were not of a very similar circumference. Less than a one inch difference overall would cause damage over enough miles,( and it ain't many guys).
Both tires need to be turning at the same speed or, the differential would be severely strained.
What freaks me is , why is the spare not properly sized to fit any of the four other tires? Seems like a crappy idea.
Old 01-11-2008, 08:27 PM   #13 (permalink)
DJJSR
DJJSR's Avatar
It's a space saver spare. I don't think a regular tire would fit in that little space in the trunk.
Don
Old 01-11-2008, 08:44 PM   #14 (permalink)
Okay, who'z got the hard data?
I wuz under the impression that the space-saver-spare wuz the same diameter. The weight n' space saved by havin' it less diameter than the real hoops seems a ridiculously small amount.
Is, 'r is not, the diameter'a the space-saver-spare the same'z the rest'a the hoops. No assumin' here guys: hard facts provided by either knowin' where to look up factory info . . . 'r somebody . . . . tape 'em Dano.
He who hates bein' wrong (but does it so frequently that it's becomin' an art form)
Old 01-12-2008, 05:37 AM   #15 (permalink)
I understand that it's designed to save space, so it's skinnier.....but why wouldn't it be the same diameter? Width of the tire would be a non-factor when we're talkin about potential differential damage. I'll work on gettin' the details.
Old 01-12-2008, 06:37 AM   #16 (permalink)
Okay, factory spare size is T125/70 D16 .
Old 01-12-2008, 06:41 AM   #17 (permalink)
'Like I said: an art form.
Thanks Jagg (I think).
Old 01-12-2008, 05:06 PM   #18 (permalink)
DJJSR
DJJSR's Avatar
125mm X .7 (aspect ratio) = 87.5mm (from rim to tire edge)
87.5 x 2 = 175mm (top and bottom)
175mm = 6.9 inches (25.4mm per inch)
16 + 6.9 = 22.9 (overall diameter of spare)
About 2 inches smaller in diameter than the regular tires. That's probably enough to screw up the rear.
BTW - the T stands for temporary.
Don
Old 01-12-2008, 05:30 PM   #19 (permalink)
Thanks Don,
that's good info to know. spare tire bad on the rears.
regards,
Old 01-12-2008, 05:31 PM   #20 (permalink)
A 2 inch decrease over stock? Oh yeah. That'll doo'er alright Don . . but . . . you already knew that.
'Had me a Blazer (a real one) whut blew it's rear some time after it'd been run with 2 different diameter tires. 'Felt like a mine blew under the rear'a the vehicle n' it really felt like we got substantial air. 'Wuz funny how all'a traffic that'd been all aroun' us n' right up our butt suddenly gave us some real room.
Okay, okay. So it wuz really a Bronco. I jus' didn't wanna give Don the satisfaction n' any more anti-Ford fuel.
Old 08-29-2009, 01:22 PM   #21 (permalink)
Jessa1200
Jessa1200's Avatar
so question, I am having trouble getting the spare tire out of the trunk. I dont need it in there and I have to pick someone up from the airport in about 1.5hrs, so I was trying to make a little more room so the suitcase fits better this time... its lefty loosey, right? Is there a tool I am suppose to use or is it just pure stength, b/c i turn left and it doesnt budge I turn right it goes a little but I am sure thats righty tighty... LOL am I doing something wrong, short on time and no guy around to help.
~Jessa~
"To be yourself in a world that is constantly trying to change you, is the greatest accomplishment." Emerson
Jessa1200 is offline   Reply With Quote
Old 08-29-2009, 01:36 PM   #22 (permalink)
MutantCheese
The Cheeziest!
MutantCheese's Avatar
Left to undo. Mine was uber tight the first time I took it out as well.
2008 S2000 New Formula Red (K&N FIPK; AUT cooling plate; Berk Ceramic coated SS headers; Berk SS HFC; Tanabe Concept G SS exhaust; Hondata toda Reflash; OEM front lip; Megan strut bar; Eibach Prokit)
2006 Civic Si NBP w/hfp kit (Too many mods to list here)
2008 CR-V EX-L w/Nav
Visit: www.GNOunderground.com
Old 08-29-2009, 01:42 PM   #23 (permalink)
Jessa1200
Jessa1200's Avatar
i got it, no man around so I use part of the tools in the car to beat the damn thing left till it FINALLY came loose... thanks.
~Jessa~
Old 08-29-2009, 01:45 PM   #24 (permalink)
MutantCheese
The Cheeziest!
We men def take our hand strength for granted. lol
Old 08-29-2009, 02:06 PM   #25 (permalink)
RMurphy
2007 Rio Yellow Pearl
RMurphy's Avatar
That's why we have tools. Sometimes, they are amazingly more effective than a man. You don't have to cook for them either.
RMurphy
Playa del Rey, CA
sifo
MODS: Rio Yellow Pearl bra and panties with CAI.
RMurphy is offline   Reply With Quote
Old 08-29-2009, 02:52 PM   #26 (permalink)
Jim21680
I was always a bit against using the spare-tire-in-a-can stuff, because once you put that in a tire, it's ruined. A plug for me is a much better idea...at least you have a chance of saving the expensive tire. But 30 lbs would be nice to save.
Anyone have an idea of what the electric motors for the top weigh? It can't be that much, but I'm surprised Honda didn't just make a manual top. I think it would be fine; the Miatas find it okay.
Old 08-29-2009, 03:17 PM   #27 (permalink)
MutantCheese
The Cheeziest!
Are you insane? The auto top is awesome. I gladly sacrifice the few pounds for the comfort of one of the fastest up/down tops on the planet.
Old 08-29-2009, 03:30 PM   #28 (permalink)
At least the top motors are in the center of the car. The spare isn't. Put in set of Recaro ProF1 SPG seats and save about 60 lbs.
Old 08-29-2009, 08:35 PM   #29 (permalink)
Jim21680
Oh no...I'm not saying I would sacrifice the top motors, even if they weighed a whole lot. I'm just saying I probably would have still bought the car, and driven it very happily, if Honda had opted for a manual top. I don't see it as a huge inconvenience - just imagine how fast you can flip down a manual top. I've seen Miata drivers do it in literally 3 seconds, latches & all.
Old 08-29-2009, 08:40 PM   #30 (permalink)
Jim21680
PS While we're on the topic of weight - I've been wondering...
If someone (of course not me...not with my car)....but if someone were to STRIP an S2000 of everything not necessary for driving, how much do you think it would weigh? Now this involves taking everything off - body panels, hood & trunk, windshield gone, airbags, lights, A/C....maybe even exhaust. Pretty much turning the S2000 into something that resembles a garage-built go cart that a couple of teenagers whipped up. Think 1500 lbs??
Old 08-30-2009, 05:57 AM   #31 (permalink)
'Place called Gempler's has a good selection'a serious tire-repair'n emergency tire-repair gear at reasonable pricez.
Old 08-30-2009, 06:29 AM   #32 (permalink)
turbosix
been done on s2ki, guy made his car track only, i forget what he got it down to... 2500lbs or so, not very light iirc
turbosix.net
Old 08-30-2009, 06:32 AM   #33 (permalink)
MutantCheese
The Cheeziest!
I have thought about removing the spare. I usually put plugs in any nail holes anyways. I keep a plug set and a air pump in my truck at all times. There is just something that makes me feel uneasy about not having the spare available tho. If I shred a tire, a plug won't do me any good. I do have AAA however.
About the auto top; one of my favorite pastimes is to pull up next to a solstice/sky and raise or lower my top....I like to see there pissed off looks and it makes my day..lol
Old 08-30-2009, 07:41 AM   #34 (permalink)
I don't play to such'a select crowd Cheese.
My favorite pastime with the top, is runnin' topless'z near'da the actual rain'z I can.
I'll put Stewie'z top up add'a red light. The obvious disappointment on the facez'a the hard-toppers (that the top goez up so quickly'n I obviously ain't gonna be gettin' drenched like they'd hoped) is a truly enjoyable pleasure.
Aaay! Yuh godda ge'cher satisfaction when yuh can, y'know?
Old 08-30-2009, 07:44 AM   #35 (permalink)
MutantCheese
The Cheeziest!
true. I do the same thing. Have you ever noticed that when you want to catch a red light so you can raise/lower your top that you catch every friggin' one green?
Old 08-30-2009, 07:53 AM   #36 (permalink)
Amen Cheese.
Itt'z'a tough thing'da'doo . . . . but sometimez yuh jus' godda take yer foot oud've'itt'n allow yerself'da get caught by'a red. (Only when absotutely necessary a'course.)
Then . . it doesn't help the case'a puttin'a topp up, when yuh kin jus' drive over 45'n the rain don't come in'a cockpit anyway.
I ain't thrilled drivin' in Stewie fer long periodz'a time with the top up. Too many new noizez'n it gettz'a wee bit claustrophobic if the drivin' not keepin' yer interest.
But, drivin' Stewie in'a wett'z at least'z innerestin'z drivin' Stewie in'a dry.
(With apologiez'da stevet fer the tangent.)
Old 08-30-2009, 07:55 AM   #37 (permalink)
turbosix
bought the car used, drove maybe 60 miles with the spare on the back
my diff is fine.
turbosix.net
Old 08-30-2009, 08:03 AM   #38 (permalink)
Six, I wish yuh nothin' but fair sailin' brutha, but the resultz'a diff'rent O.D. tires on'a rear don't alwayz make'emselvez known immediately.
I hope you got away widd'itt, but jus' 'cauze yuh did don't mean itt'z somethin' whut should be done.
"'Had me a Blazer (a real one) whut blew it's rear some time after it'd been run with 2 different diameter tires."
Old 08-30-2009, 08:11 AM   #39 (permalink)
MutantCheese
The Cheeziest!
I wouldn't risk it myself.
Old 08-30-2009, 08:29 AM   #40 (permalink)
Jim21680
I'm certain there's a way to get around the need to have the hand brake on for the top to work. In my RX-7, I could pull the lever up just enough to get the brake light to come on, and then the top would work (allowing to raise or lowering while driving slowly). This doesn't seem to work in the S2000. There's probably a basic wiring loophole to get around...anyone know?
amp, bad, damaged, diameter, differential, honda, installation, location, rear, roads, s2000, saver, space, spare, tire
