Old 05-10-2008, 05:08 AM   #41 (permalink)
xredjar
I bought my 06 with under 10k on the clock. Still had the original RE50s on it. I'm over 16k now and they still have more than 50% tread left.
xredjar is offline   Reply With Quote
Old 05-10-2008, 11:04 AM   #42 (permalink)
jwh445
2005 Stock Silverstone
jwh445's Avatar
Originally Posted by Vezna31 View Post
Yep...you're not driving hard enough. Also...your pedal feels mushy because you boiled the fluid. You need to bleed the brakes. You should be using something like Motul 600 or Ate Super Blue for track days. Regular DOT 3 and 4 don't cut it.
I am going to purchase Powerslot rotors with Hawk HPS pads and steel brake lines. Upon install, I will replace my fluid with Ate Super Blue. I read alot about brakes here and the general consesus seems to be the OEM stuff is good enough for most. As I am no expert (yet), I think this setup will work fine. Not ready for new calipers or bigger rotors. I may consider purchasing some track specific pads for my track days. Not trying to hijack this thread, sorry.
jwh445 is offline   Reply With Quote
