Old 05-20-2008, 05:10 PM   #41 (permalink)
gyshiga
Originally Posted by Seattle2k View Post
Huh? The OEM dampers are Showa. Not sure it matters who makes them. Simply put, 2 inches is way too low for the OEM dampers to take. They weren't made for the duty of living that compressed all the time. You run the risk of them nailing the bumpstops or bottoming out. (read: BAD). If you want to go 2 inches lower, go with coilovers.
Low profile tires will NOT lower your car closer to the ground. They will NOT reduce wheel well gap either. Running +1 (17") on the OEM wheel size (lower-profile tire) will aid in corning performance and steering response, as you have less sidewall flex to worry about. You start losing performance, when going +2 (18"), due to increased rotational/unsprung weight. This increased wheel weight will also increase stopping distance. A smaller diameter tire will lower your car effectively, but will increase wheel well gap. At the other end of the spectrum, a larger diameter tire will raise your car and decrease wheel gap.
400 for springs? Ouch!
Also, as others mentioned above....without a camber kit, you're not going to be able to get a 2" drop in to spec.
thanks for the info. so the coil overs wont put the pressure on the dampers?
yea, i spent 400 for tien springs and installing them.
i thought skunk2 would be the economic way to go to lower it more than 1 inch (which i currently have)
but i can save up and get coil overs i guess.
how long do you think the dampers will last with a 2 inch drop with skunk2 springs?
gyshiga is offline   Reply With Quote
Old 05-27-2008, 11:49 PM   #42 (permalink)
gyshiga
Originally Posted by SilverS2K422 View Post
i got the skunk2, but im putting them on thursday. so ill let you know
how are they?
after they settle, are the tires rubbing the top when you do a full turn?
Old 05-28-2008, 06:52 PM   #43 (permalink)
SilverS2K422
SilverS2K
SilverS2K422's Avatar
actually i just got them put on today, there awsome so far!!!
Old 05-29-2008, 12:56 AM   #44 (permalink)
gyshiga
without the settle, is there space to put a finger in?
or it has to settle.
take a picture and post it on your myspace page?
i'm not scraping on bumps or drive ways with my tien.
could go a little lower.
i can fit one finger all around after it has settled in.
Old 05-29-2008, 10:33 PM   #45 (permalink)
SilverS2K422
SilverS2K
ill post some pics on here when i get the chance. you cany fit ur fingers above the back tires at all and almost fit one in the front, guess they made the springs like that to level the drop out. there is no front downward angle with the springs its just like ----- perfectly level. its looks awsome i love it.
Old 06-04-2008, 12:39 AM   #46 (permalink)
Seattle2k
Energy Motorsports
Seattle2k's Avatar
The dampers in a coilover are designed for the lowered use..
Oh, okay... 400 installed makes more sense!
How long will stock dampers last with a 2inch drop? I dunno. I guess it depends how old the dampers are and how hard you'll be pushing them with the drop. I'm just saying they will have a shorter life. Just like putting boost on an S2000....it won't last as long as a stock n/a car.
PM me about discounts on Seibon carbon fiber and Tein lowering springs. www.energy-motorsports.com
Seattle2k is offline   Reply With Quote
Old 06-04-2008, 06:59 AM   #47 (permalink)
lonestarbuzz
lonestarbuzz's Avatar
any pics yet silver?
i need a better signature.
Old 06-04-2008, 04:11 PM   #48 (permalink)
SilverS2K422
SilverS2K
not yet sorry, i dont have a camera. soon though, if i can get a camera today ill post them later tonite
Old 06-14-2008, 09:32 PM   #49 (permalink)
BrettRedS2K
The New Guy Around Here
BrettRedS2K's Avatar
Send a message via AIM to BrettRedS2K
So if I install the 1.5 inch drop with springs I am doing next week I "should" be able to get the camber readjusted without a camber kit?
Brett
2005 NFR S2K
BrettRedS2K is offline   Reply With Quote
Old 06-15-2008, 09:04 AM   #50 (permalink)
Pablo
Sentient Being
Pablo's Avatar
Hey Brett
Sorry for changing the subject if ever so briefly, but your sig graphic is absolutely the most AWESOME piece of creativity I've seen in a long time. Good job Dude!
Regards,
Pablo
Old 06-15-2008, 01:56 PM   #51 (permalink)
gyshiga
one of my friends got skunk springs and is a bit lower than mine, i have tiens. its about half or a bit more of half inch drop all around.
doesnt seems too low to harm anything. i know the car can support tiens.
but once you drive the car, you can feel the difference. it seems a lot lower to the ground, but softer springs with the skunk.
a bit higher with the tiens but the springs are harder so you can feel the road.
i was a little drunk so going to drive it again.
The car seems to be able to handle skunk springs.
Old 06-15-2008, 02:25 PM   #52 (permalink)
stimpgsx
URDADDY!
stimpgsx's Avatar
wht you blow your shocks ,get some bilstein pss or pss9's . you wont regret it.
stimpgsx is offline   Reply With Quote
Old 06-15-2008, 06:31 PM   #53 (permalink)
bobby2002S2K
bobby2002S2K's Avatar
1.5 inch drop you can adj you stock camber and be good, any lower and you got to get a camber kit to get the right camber.
Old 06-15-2008, 06:53 PM   #54 (permalink)
BrettRedS2K
So when they do the alignment after the drop that would include usually a camber adjustment to right?
Brett
2005 NFR S2K
Old 06-15-2008, 10:36 PM   #55 (permalink)
SupeR_DavE
S2k Driver
SupeR_DavE's Avatar
most shops will include the camber adjustment as part of the alignment,but you will always have some shops that will nickel and dime you to death,those crooks...lol
SupeR_DavE is offline   Reply With Quote
Old 07-06-2008, 03:43 PM   #56 (permalink)
gyshiga
i heard nu speed has a 1.25 to 1.5 drop
sounds good.
i have tien and only dropped 1 inch.
rides expectionally well. its a hard ride (which i like)
but a bit high, and doesnt look like a lowered car
skunk feels softer for some reason.
drops 2 inch, looks good, not as low as you would think. just have to drive more slower on driveways
does anyone know how nu speed springs rides, or any other springs thats lower than 1 inch?
Old 07-06-2008, 07:45 PM   #57 (permalink)
s2jiggy
I have megan racing springs, and found that although they have the perfect drop, 1.5 inches, they are very soft. Not sure what the spring rates are, but definitely the stock springs seem stiffer.....
2003 Pontiac with Guinness (Thanks Jagg...)
Although recently sold, there will be another
s2jiggy is offline   Reply With Quote
Old 07-07-2008, 05:49 AM   #58 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
Am I the only one who saw this??
Old 07-07-2008, 06:56 AM   #59 (permalink)
DJJSR
DJJSR's Avatar
Good point, Dez.
I recommend that if you're going to drink and drive, use the cheapest springs you can find. You inevitably are going to crash the car anyway, so why waste money on expensive springs?
Don
Old 07-08-2008, 07:41 PM   #60 (permalink)
f20milo
f20milo's Avatar
I found some skunk2 lowering springs for around 200 bux that lower the car about 2 inches. Is that pretty low for the S? I want to keep or imoprove the great handling, would the springs make it better or worse?
Thanks
Springs wont do anything for your handling.. If anything they worsen it.. I have Espilr's and I love the drop they give you.. Feels awesome too.
S2k's #1
f20milo is offline   Reply With Quote
Old 07-08-2008, 10:02 PM   #61 (permalink)
SilverS2K422
SilverS2K
i would have to disagree with that. i got the skunk2 and my handling feels alot better than it did before. i can take turns a bit faster with the springs than before. i will say it drops the ride comfort down alot but i dont really care.
Old 07-09-2008, 12:00 AM   #62 (permalink)
gyshiga
skunk2 has a nice drop, soft ride.
i'm thinking about the nuspeed 1.5 drop.
anyone heard about their ride?
tien has a hard ride, which i like, but only has a 1 inch drop
dosent look like a lowered car
(my friend has a s2k, with skunk springs)
i was drunk when testing his new springs
Old 07-09-2008, 06:17 AM   #63 (permalink)
SXY_S2K
Trqless
SXY_S2K's Avatar
Wait WHAT?!?!?!?
www.myspace.com/kesmith3
Old 07-09-2008, 08:08 PM   #64 (permalink)
gyshiga
Originally Posted by SXY_S2K View Post
Wait WHAT?!?!?!?
my friend has a s2k as well. and he recently got new springs (skunk2)
when i test drove it, i was drunk.
Old 07-09-2008, 09:36 PM   #65 (permalink)
SilverS2K422
SilverS2K
not smart!
Old 07-10-2008, 08:36 AM   #66 (permalink)
Pablo
Sentient Being
Pablo's Avatar
It was OK to test drive the car drunk.....
It was his FRIENDS ride!
Regards,
Pablo
Old 07-10-2008, 08:58 AM   #67 (permalink)
dezignpro04
All MOTOR S2K
You also sound drunk when entering your threads. Instead of explaining over and over that you "were drunk", say, "My bad, I'm a dumba$$ and will never do that again!"
