Old 04-16-2008, 08:25 AM   #1 (permalink)
Ualreadykno
Ualreadykno's Avatar
Mix/match tires question???
Bought my baby 2weeks ago used. She has 2 different sets of tires on 'er. Is this not a good thing? Bridgestone 225/50R16 (rear) Yokahama AS430 205/55R16 (front). Also have slight vibration at about 90mph. Not sure if it may just need a wheel balancing tho. Going to replace wheels and tires when these wear out but if its a bad combo I'll do it sooner. Thnx guys
Remember....Use your S2000 and love people....or is it the other way around???
Ualreadykno is offline   Reply With Quote
Old 04-16-2008, 12:13 PM   #2 (permalink)
Ualreadykno
Anyone???
Old 04-16-2008, 12:17 PM   #3 (permalink)
SXY_S2K
Trqless
SXY_S2K's Avatar
I don't think it should be a problem as the long as the fronts and rears are matched pairs. But I would get them balanced, and check to make sure there are no bubbles in the tread(could be causing the vibrations, altho not super common). If there are bubbles or imperfections in the rubber it could cause a blowout... Blowout=Bad news...
Have you had it aligned?
www.myspace.com/kesmith3
Old 04-16-2008, 12:19 PM   #4 (permalink)
SXY_S2K
Trqless
SXY_S2K's Avatar
Edit - Re-read post - 90?!?!?!?!?!
I'm pretty sure things are gonna vibrate at 90MPH no matter what!!!
Slow down, get to know her first, you've only just met
Old 04-16-2008, 12:38 PM   #5 (permalink)
Ualreadykno
haha you're right. Thnx
Old 04-16-2008, 12:45 PM   #6 (permalink)
In my conversations with Jim at Tire Rack (he is THE guy to talk to there when it comes to the S2000), he specifically told my NOT to have different makes of tires on the car. I would suggest getting matching pairs.
Old 04-16-2008, 12:48 PM   #7 (permalink)
Ditto whut Go said. It's not ta say that it's a harbinger'a doom, but it could be.
A tire of less grip in the rear than whut'z on the front could take the normal oversteer to nasty levels n' it's not somethin' that mere mortals can tell.
Trust the guy'z at the 'Rack.
Old 04-16-2008, 08:58 PM   #8 (permalink)
Ualreadykno
Thats what I needed to know. Thnx guys!
Old 04-17-2008, 02:46 AM   #9 (permalink)
RuffRyder
Brooklyn!!!
RuffRyder's Avatar
Send a message via AIM to RuffRyder
when I bought my S the guy that sold it to me made sure to match everything. Left me on 205's all around. I felt a straight civic stance.
Anyways, I handled that problem quick. 205's in the front, 245's in the rear.
Sure feels good to take those turns....... hard
FOR SALE THREAD ! ! ! !
http://s2000.com/forums/parts-for-sa...html#post57051
RuffRyder is offline   Reply With Quote
Old 06-16-2008, 10:12 AM   #10 (permalink)
NEIGHBORHOOD LEGENDS
NEIGHBORHOOD LEGENDS's Avatar
So its fine to have dif sizes front and back as long as the brand and model is the same?
Neighborhood Legends-Chicago
Proud Chicago Lowrider Council Member
NEIGHBORHOOD LEGENDS is offline   Reply With Quote
Old 06-16-2008, 10:33 AM   #11 (permalink)
DJJSR
DJJSR's Avatar
NL - The newer cars come stock with 215/45-17 up front and 245/40-17 rears.
Don
Old 06-16-2008, 11:50 AM   #12 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
Good point. This car takes some getting used to. Very different from most in terms of handling.
On a side note, my car rides great at 90+. No shakes at all. Maybe it is something he should look into...
Just my .02, which is only worth about .01 now-a-days..
Old 06-16-2008, 12:10 PM   #13 (permalink)
sonic
sonic's Avatar
Sometimes the best way to learn how to swim is to just jump in.
GO FAST OR GO HOME
Old 06-16-2008, 12:13 PM   #14 (permalink)
dezignpro04
All MOTOR S2K
Then when the person drowns, you say, "Maybe I should have taken them for lessons..." lol j/k Sonic..
For some it works that way, for others it dosent. It just depends..
Choose wisely young grasshopper!
Old 06-17-2008, 10:02 AM   #15 (permalink)
I guess mine is too old its a 2001 and my front and rear tires are the same size....What should I do? Keep it that way or do the new school way?
Old 07-01-2008, 08:56 PM   #16 (permalink)
k20a
k20a's Avatar
I don't think different tires brands could cause vibration. you can check other suspension components to be sure...
k20a is offline   Reply With Quote
