Old 05-20-2008, 12:58 PM   #1 (permalink)
sittin-sidwayz
The Man
sittin-sidwayz's Avatar
Wheels on ebay
Would these fit on a s2000??
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
sittin-sidwayz is offline   Reply With Quote
Old 05-20-2008, 01:23 PM   #2 (permalink)
archs2000
pretty sure, that is if you don't want to keep a staggered setup
archs2000 is offline   Reply With Quote
Old 05-20-2008, 01:32 PM   #3 (permalink)
dezignpro04
All MOTOR S2K
dezignpro04's Avatar
They will, but not going staggered will affected the cars handling. Also putting 18x8 up front is kinda big. You could always run 18x8 all the way around with maybe 235 up front and 245 or 255 in back but you will need to modify the cambers to get them to roll under the fender. Remember that the OEM is (if I am not mistaken) 7 inches wide up front and 7.5 wide in the back. They are very nice rims, would look great on a Silver with red interior, or maybe my car. lol. But IMHO I wouldnt put 18x8 up front.
just my 02..
dezignpro04 is online now   Reply With Quote
Old 05-20-2008, 01:33 PM   #4 (permalink)
U.C.M S2K
U.C.M S2K's Avatar
m.... i m thinking about getting this rims.. does anyone knows more detail for this rim.. cuz i just bought my s2000 last year .. wut kind of rim should i get? i have bk s2k.. i m thinking about this brand.. is this good for s2k?
U.C.M S2K is offline   Reply With Quote
Old 05-20-2008, 01:40 PM   #5 (permalink)
dezignpro04
All MOTOR S2K
It's not as much "brand" as it is application (aka size).
Start by reading my post above yours...
Old 05-20-2008, 06:43 PM   #6 (permalink)
Grumpy old(er) phart
Following are the specs for the fronts and rear wheels. Pay particular attention to the offsets, they are most important followed closely by the bolt pattern.
Fronts - 17x7.5 (diameter x width), +52 (offset), 5x114.3 (bolt pattern)
Rears - 17x8.5(diameter x width) , +59 (offset), 5x114.3 (bolt pattern)
Old 05-20-2008, 07:24 PM   #7 (permalink)
Or 16 x 6.5 offset +53 front
16 x 7.5 offset + 65 rear
Old 05-20-2008, 10:07 PM   #8 (permalink)
Ask java I think he made a booboo once ordering rims. What did you ever do with those rims java?
2001 Vortech SC
12.8 at 111 miles per hour
Old 05-21-2008, 12:30 AM   #9 (permalink)
JOECHY
JOECHY's Avatar
Are you refering to stock wheels 2004+?
Old 05-21-2008, 03:10 AM   #10 (permalink)
This is the specs for the Mugen wheels which will fit any S2k...they are designed for exact fit.
Old 05-21-2008, 04:03 AM   #11 (permalink)
Yep isu, yuh remember correctly.
Deep in the throes'a shiny-bauble-induced desire (Thinkin' with partz'a the body meant fer other thingz) I allowed myself ta be conned by a salesman ta the tune'a set'a 5-Zigenz.
Bottom line is they haven't godd'em with the adequate positive offset necessary to properly fit Stewie'z rear. End result wuz, once mounted, rough pavement (A given locally) n' heavy cornerin' reminded me of my ol' Physicz teacher goin' on about "Impenetrability": No two objects can occupy the same space at the same time.
Currently, two'uv'em'r pullin' duty'z dusty, good-lookin' paperweightz out in'a garage.
The scrounger "borrowed" this from another site'n it's posted in the wheelz/suspension section, but evidently, ain't alodda memberz whut wanna go lookin'.
Whoops! 'Seem to've lost it. 'Be right back.
Okay, fer some reason it ain't allowin' me to copy'n paste.
It'z on the 5th page of the threadz listed under the wheelz/suspension topic.
