The Man
i think these would look nice!
how can you tell if these will fit all around the s? It say's 17x7, will those fit right? http://www.wheelsnext.com/wheels-tir...ck%20Flat.html
The Man
and also, when you pick your tires they only give you 215/45/17.
All MOTOR S2K
Those rims are HAWT!!! I would suggest getting a staggered setup, not only in tire size but also in rim width.
Then again I love what you did to your stock rims... Keep those or give them to me when you buy new rims.. lol Just my 02.
The Man
haha, def, i think we could work something out!! lol and yea, i'll have to call them and see if i could get a staggered setup!
it didn't look like you can get a staggered set up online. you will have to call them. i really like those wheels tho. let us know what they said!
i need a better signature. |
The Man
I'll def. let you know, i called them but i was on hold for about 15 min. so i said f*ck it!! I sent them an email lol But i'll let you know when i get a response!!
sidwayz,
You might want to make sure the offset is correct or you could be chewing up wheel bearings and may have rubbing issues if you need to go to a 18 in rear to maintain the stagger. I like the gunmetal is that what you are considering? |
All MOTOR S2K
SXY ROX!!!
Trqless
lol, oooops, deleted my post bc I am checking to see if he still has them in stock. Will let ya know!
The Man
ok, im gonna def look into that!! And either the gunmetal or the flat balck! there both sick!!
Grumpy old(er) phart
Where? Who's sick? Who are they (must be two of them because they are both sick)
The Man
#13 (permalink) | |
Those wheels are hot!
But from just looking at the website, on the bottom the only staggered set up listed is 19X8.5 front and 19X10 rear |
The Man
#16 (permalink) | |
Don't taze me bro!
#17 (permalink) |
Look, I dunno fer sure okay? But when they put that much time in on tellin' yuh how great they are'n never once mention whut the offset izz . . ya kin pretty much take it to the bank that these are common offsetz (Read: non-Stewie) n' the whole purpose'a this exercise it to ge'cha ta salivatin'n' spendin' yer money on stuff without verifyin'att it'll fit'r, at the very least, not give'ya grief.
N' don't think that the salesman tha'cha call up'z alwayz gonna be on the up-n'-up. Once they ge'cher money'n' their product shipped off to yuh, the problem is yours. N' if this soundz like I might'a been stung by an operation like this before, you're readin' it right. When the offsetz ain't listed in the primary info dump, there'z like a 99% probability that they ain't the extreme offsets that you need for them to go 'round'n round on Stewie without doon damage to hardparts in'a process. N' if the spec (offset) ain't right'n you're still goin' back ta the site'n droolin' over'em . . . whu'cha are is'n accident waitin'a happen kiddo. Do yerself a big favor'n delete the site from yer favoritez'n move on. Java
#18 (permalink) |
Good choice. What do those weigh?
Steven ![]() 2005 "Guhn-Metal" AP2 -MySpace --http://www.myspace.com/jedichu -Annihilator Customs --http://www.annihilatorcustoms.com |
#19 (permalink) |
Based on successes and failures from many S2000 owners, we can use an offset calculator to figure out what other offsets and tires will work. These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance.
For the front: 6.5” to 7.5” wide wheel: 205 tires: +43 offset minimum 7.0” to 8.0” wide wheel: 215 tires: +48 offset minimum 7.0” to 8.0” wide wheel: 225 tires: +53 offset minimum 7.5” to 8.5” wide wheel: 235 tires: +58 offset minimum 7.5” to 8.5” wide wheel: 245 tires: +63 offset minimum For the rear: 7.5” to 8.5” wide wheel: 235 tires: +40 offset minimum 7.5” to 9.0” wide wheel: 245 tires: +45 offset minimum 8.0” to 9.5” wide wheel: 255 tires: +50 offset minimum 8.5” to 9.5” wide wheel: 265 tires: +55 offset minimum 9.0” to 10.0” wide wheel: 275 tires: +60 offset minimum 9.0” to 10.0” wide wheel: 285 tires: +65 offset minimum The offsets above will all set the outside edge of the tire to the same place relative to the outer fender, rounding to the nearest millimeter
#20 (permalink) |
Nah, he's a bit weak in the punctuation department...should have been: There. Both sick! and ergo, you got two they's and they're both sick somewhere...unless he was passing along a virus and he meant There..both sick (he said with an air of satisfaction)
#21 (permalink) | |
Don't like them for your car, wrong colour...........but they're good for mine ! Neil |
#22 (permalink) | |
The Man
#23 (permalink) |
Anytime s-s.
#24 (permalink) |
s2k4life
Hey man, if you end up getting those wheeks, make sure you post some pics, because those are the ones I want to get
