wheel assistance
Hey everyone,
just purchased an 05 honda s2000 and ready to change my rims. I got a set of mugen mf-10 rims, 17" x 8" offset +55, can they fit on the S? Desperately awaiting a reply |
The common wheel size chart:
As written by spa-zz: These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance. For the front: 6.5” to 7.5” wide wheel: 205 tires: +43 offset minimum 7.0” to 8.0” wide wheel: 215 tires: +48 offset minimum 7.0” to 8.0” wide wheel: 225 tires: +53 offset minimum 7.5” to 8.5” wide wheel: 235 tires: +58 offset minimum 7.5” to 8.5” wide wheel: 245 tires: +63 offset minimum For the rear: 7.5” to 8.5” wide wheel: 235 tires: +40 offset minimum 7.5” to 9.0” wide wheel: 245 tires: +45 offset minimum 8.0” to 9.5” wide wheel: 255 tires: +50 offset minimum 8.5” to 9.5” wide wheel: 265 tires: +55 offset minimum 9.0” to 10.0” wide wheel: 275 tires: +60 offset minimum 9.0” to 10.0” wide wheel: 285 tires: +65 offset minimum Congrats on the purchase and welcome!
02 S2000 Berlina Black/Black 08 Acura MDX 03 Acura MDX |
according to the chart, it will work. but i would run wider tires in the back for sure. the S is really set up to have wider tires in the back.
congrats and welcome!
i need a better signature. |
There you go.
thanks guys,
do you suggest 215/45/17 in the front and 225/40/17 in the back. Also, i want to get some lowering springs; 1 1/2 drop max, any suggestions? |
The newer cars come with 215/45x17 up front and 245/40x17 on the rear.
Don |
Go with 215 Front, 245 Rear, you'll be good to go
04' NFR-Comptech - Veilside - Rick's - Fujita - Grillcraft - Tein - NRG - Berk - Chargespeed - Lucid - Carbing - Megan - T1R - Alpine - Boston Acoustics |
yea, but if I'm going to lower the car 245 won't be too big. Also, considering the rim is 8" in width will 245's fit?
One other thing; the rims that I have are 8" in width and +55 offset all around but the oem rims are 7.5 in the front, +55 offset and 8.5, offset +68 in the rear.
#10 (permalink) | |
#11 (permalink) | |
Yes 245 will fit, and yes you should be ok lowering it.
#12 (permalink) | |
Your oem rims are 17x7 +55 front, and 17x8.5 +65 rear
04' NFR-Comptech - Veilside - Rick's - Fujita - Grillcraft - Tein - NRG - Berk - Chargespeed - Lucid - Carbing - Megan - T1R - Alpine - Boston Acoustics Last edited by s2k 4 me : 07-11-2008 at 12:05 PM. |
