Old 09-04-2008, 06:49 PM   #1 (permalink)
RL1924
RL1924's Avatar
Wheel Creeking???
I got my alignment done about 3 days ago and just today seems im getting an odd creeking noise when i turn to the left, Its only when i am basically stopped i am assuming from the resistance, It dosent happen throughout a turn just a section of turning the wheel, If you get what im saying basically say the wheel is straight and i start turning to the left the noise soon starts then stops as i continue to turn the wheel.... Now this didnt happen right after my alignment but few days it may have nothing to do with it... Any ideas???
Old 09-04-2008, 08:59 PM   #2 (permalink)
JOECHY
JOECHY's Avatar
In my opinion, it sounds like your CV boot may be leaking oil causing friction in the CV joint/assembly. How many miles on your car?
JOECHY is online now   Reply With Quote
Old 09-04-2008, 11:08 PM   #3 (permalink)
philiam
There are several places that may be binding. Possibly the rack and pinion has a bad spot.
Old 09-05-2008, 05:19 AM   #4 (permalink)
RL1924
RL1924's Avatar
Only 33,000 miles... hmmm
Old 09-05-2008, 06:12 AM   #5 (permalink)
DJJSR
DJJSR's Avatar
Maybe check the simple stuff first. Tighten your lugnuts and USE A TORQUEWRENCH (very important with alloy wheels). 80 ft/lb is the spec.
Don
Old 09-14-2008, 09:58 PM   #6 (permalink)
suzukablueap2
BeaveRun, PA
suzukablueap2's Avatar
Send a message via AIM to suzukablueap2
does it creak if the car is motionless but you turn the wheel to the left?
Maybe inspect your ball joints.
suzukablueap2 is offline   Reply With Quote
Old 09-14-2008, 10:09 PM   #7 (permalink)
RL1924
RL1924's Avatar
Yea thats exactly what it does but it seems to not really be doing it anymore
Old 10-14-2008, 09:52 AM   #8 (permalink)
Grounded
something loose.
get under the car & tighten everything you can find
related to the body, suspension, steering.
you'll find it.
goodluck
Grounded is offline   Reply With Quote
