Alignment specs
From Kevin (mlc):
Here are the UK specs for AP1. Honda (UK) Recommended Optimum Specification Front Caster Left 6° 45" Caster Right 6° 45" Camber Left -1° 00" Camber Right -1° 00" Toe Left 0° 0" Toe Right 0° 0" Total Toe 0° 0" Rear Camber Left -2° 00" Camber Right -2° 00" Toe Left 0° 20" Toe Right 0° 20" Total Toe 0° 40"
From Pedel faster on S2KI:
A proper alignment is important for autocrossing, and compared to the other changes you'll be making, a bargain at less than $100. Individual alignments vary, but for the AP1 cars, the general consensus falls in the following ranges:
Factory specs for AP1:
Factory alignment spec Front Camber -0.5d +/- 0.17d Caster +6.0d +/- 0.25d Total Toe In 0+/- 2mm Rear Camber -1.5d +/- 0.17d Total Toe In 6mm
What I believe are the specs for AP2, but I may be incorrect, Anyone confirm or correct?:
Front Left/Right Camber -0.2deg/-0.5deg Caster 7.8deg/5.7deg Toe -0.05"/-0.10" Rear Left/Right Camber -1.4deg/-1.8deg Toe 0.1"/0.07"
FIGHT THE POWER!!!
Can we make this a sticky? This is awesome information put in one post.
wow, thanks... I got AP1 with stock shock but my tire change already to the AP2 wheels, so I got front 215/45/17 and the rear 255/40/17.
so which spec I should do?? and in the future i want to change the front one to 225/45/17.. is it going to be better?? |
cone destroyer
I like your new avatar GO, very nice...
![]() Koni shocks, Tein lowering springs, Invidia exhaust, CR front and rear sway bars,Neuspeed X-brace, stock test pipe, goodridge ss brake lines, more to come..... |
What are the specs for AP2? I mean UK specs, for better handling?
BUMP - I'm looking for UK Specs for an AP2 also ...
2007 Berlina S2K OEM Lip.Swift Springs w/Koni Yellows.Level Mirrors.Ap2v3 Wheels. K&N Filter/Gutted Box.CTR Knob. Oh, and SEAT LOCKS! |
There were no UK specs for the AP2. That alignment was done in the UK after they were complaining about the car having a tendency to oversteer. The suspension was revised on the AP2 so hence they didn't have a different alignment for it.
Kevin |
The track specs that I got happy with on my AP2 were
Front Max Caster but matched, got 6.4° Camber -1.7° Total Toe Out ⅛" Rear Camber -2.1° Total Toe o" (no toe) I don't think that I'll do any more experimentation beyond this. On my AP1, I had a lot more toe out in the front and substantial toe in in the rear.
old, rude, grumpy track junkie |
That's good to know Apex.
How's the streetability? jagg |
Hey Dudes I just got my alignment doe and here is what it is set at BTW works Bitchin' Front Camber- right -0.7 left -0.7, Caster right 5.8 left 5.7, Toe right 0.0mm left 0.0mm Rear Camber- right -1.9 left -1.9, Toe right 3.0mm left 2.8mm
#16 (permalink) |
The only issue is the uneven wear on the front skins because of the toe. I take most turns pretty fast so the quick entry response from the front toe is okay with me. I thought that it might be twitchy in a straight line but that's not the case.
#17 (permalink) |
Thanks Apex.
#18 (permalink) |
OK, no UK Specs for an AP2 ... so does anyone have suggestions for what would be a touch more aggressive setting? MY07, I'm dropped on Swifts w/ Koni Yellows - with Direzza Z1 Star Specs. Maybe just Factory settings on Toe and Caster, then pushing the Rear Camber out a bit more? This is my DD, but I want to have the rear firmly planted / at the same time not COMPLETELY destroy the tires on the inside. Suggestions?
#19 (permalink) | |
#20 (permalink) |
Someone mentioned going with CR Alignment specs ... any thoughts on going that route?
#21 (permalink) |
any uk specs for the ap2?
is so please post.. ths |
#22 (permalink) |
help ???
Does the specs change if you have bigger tires ?? Im running 265/35/18 on the rear and before I got new tires and an alignment my rear tires were wearing real bad from the inside out. Old tires lasted about 4000 miles and the insides were gone. Now, I got new tires and alignment and Im still worried my tires are still wearing from the inside out. After a short drive I felt the tires and the inside was hot and the outside was cold on both tires !!! WTF ?? Tires are too expensive to be replacing after 3-4000 miles. Any help would be great.........??? Do I need to have different settings than stock ? They have the rear specs on my car @
Camber -1.5 deg on the left and -1.4 deg on the right toe 18 deg on the left and 20 deg on the right They claim camber -1.7 to -1.3 deg toe .16 to .32 deg as the specified specs factory settings ?? Are they ok ? |
#23 (permalink) |
The more negative camber you run, the more the inside of the tire will wear.
#24 (permalink) | |
Car Dummy
Toe is the main alignment factor that causes tire wear. If your toe is .18 degrees L .20 degrees R, that really stands out as a tire killer as they are .38 degrees in opposite direction (total toe), which is a considerable amount. Then again, positive toe means toe in, which would likely lead to outer tire wear/scuffing. Try getting your camber back to -1 degree on each side and get that toe fixed, as GM3 said excessive negative camber will wear the insides. No toe is good toe! |
#25 (permalink) |
Oversteer
07 Alignment
My owners manual says:
front camber -.5 degrees front toe 0" to out 1/16" caster 6 degrees I'm going from memory so I might be off on the caster a little. Rear camber -1.5 degrees Rear toe in .15" total For Auto cross I have: Front camber -1.75 degrees Front Caster + 4 degress or as close as you can get Front Toe I have set at 0" but 1/16" out is acceptable Rear Camber -2 degrees or as close as possible Rear Toe 1/4" In I run R-compounds for Racing. This setting is a little twitchy on the street but no bad. If the road is smooth you don't notice anything different. This works well, and as it turns out when I took it to my Goodyear shop for a percision alignment they already had it in the computer as an acceptable performance setting from Honda. |
#26 (permalink) |
My current Camber/Caster/Toe settings for my '05 AP2:
-Front toe - 1/8" OUT -Front caster - +5.5degs -Front camber - -1.5 degs -Rear toe - 1/4" IN -Rear camber - -2.1 degs When I had my alignment done, the front right wheel camber maxed out at -1.9degs, while the front left wheel did at -1.5degs. Then, the front right was brought back to match the left front wheel settings. Street driving conditions: The car behaves very much as stock, perhaps with a better steering response. Autocross conditions: Sweeping curves performance has improved considerably. I wonder what my AP2 does on the skid-pad. I hope it can make it up to the 0.92g lateral acceleration as of the AP1... Slalom performance requires the driver to be some what more awake, as the loading on the car shifts from one side to the other...it wants to bite when on the edge... Street driving and autocrossing is done with the stock tire configuration, using Dunlop Direzza Sport Z1 Star Spec. I'm not that worried on the tires wear, the alignment was done when they were at more than half way done. Next upgrade will be a set of R comp tires...perhaps next year I found some useful info at the honda press release site: http://corporate.honda.com/press/art...20010221001307 although, I couldn't get a hold of the for the AP2 tech specs in there. Last edited by angelo_s2k; 06-04-2009 at 05:57 PM. |
#27 (permalink) |
This thread is awesome thanks GO
"Dream as if you'll live forever, Live as if you'll die today." - James Dean |
#28 (permalink) |
Oversteer
Skid Pad
I have an accelerometer in my car when I race. Don't know how accurate it is. But, I was getting 1 g on street tires part of the time on wet asphalt. On R compounds I can get a consistant 1.25 G with an occasional spike higher. The longer I can hold the car at the higher g levels the better my times. I don't know how the accelerometer would compare to timing laps on a skid pad.
| 2003, 2007, alignment, allignment, ap2, autocross, camber, honda, rear, s2000, settings, specification, specs, stock, uk |
