I need opinion about tires
is NExen a good tire or falken better??
I got confuse about this 2 because the nexen is cheaper |
Andiamo Veloce
I don't know anything about Nexen but I do know Falkens are great tires.
I'm running Falken 452s now and love them. not too expensive and good and sticky in the turns. |
Bridgestone RE-01R is the best warm weather tire you can buy.
i am replacing my rears this week.putting falkan 452's on the rears. the rears lasted 16,000 miles. the fronts are like new still.i change my tires when i am close to the ware bars.dont like the ride too hard...i guess i could run these another 5,000 miles if i had too.
Run a comparison on Tirerack.com.
Hey bat, how are they in the wet?
Andiamo Veloce
Very predictable. I don't press hard on wet surfaces but the fell is there and you always seem to feel the control.
I like em... I'm on those in the vid below.
-------------------------------------------------------------------------------------------- ![]() Nikola Tesla,I salute you. Last edited by batguano; 12-01-2008 at 05:11 AM. |
Banned for Life
I would go Falken. Also check out Kuhmo, Wanli and Nankang. Hope that helps.
Mike
![]() Mods: 18" Axis Reverbs w/Black Rays Lugs, Invidia N1 Exhaust, CAI, ACT Stage 2 Clutch, JDM Side Markers, Clear Corners, Slotted/Drilled Rotors, Spoon Pads, Spoon Steel Brake Lines, Spoon Reservoir Socks, Ricks Vodoo Knob, Custom Stitched Hand Made Convertible Top w/ Glass Window, JDM Aero Screen, Body Matching Dash & Shift Molding Panels, Polished Valve Cover and CAI, Engine Steel Braided Wire Kit & S2000 Caliper Vinyls.. Last edited by dezignpro04; 12-01-2008 at 12:58 PM. |
Raconteur
you need 4, one on each corner and then you have to remember that what is on the road at any moment is an area no larger than a hard-cover book so cheap tires and a tread section about 8"x6" is the only thing keeping you from serious harm....if you can't buy 4 good tires immediately, you buy the best two you can get to replace the worst ones and then buy the others when you save the money. You can't skimp on tires, brakes or steering...those are the things that keep you from getting seriously damaged...(and Jonathan is correct..at the moment, Bridgestone RE-01Rs are the best warm weather tire made...he made a recommendation)
I would like to add that you need to replace the worst tires, but they should be on the same axle (i.e. either the fronts of the rears). If you were to replace the two worst tires and they are on just the driver side, you will have better traction turning right than you do turning left. As well, the car will swing side to side in between each shift/ letting off of the throttle due to the difference in tire diameter on the rears (like having different air pressures in each rear tire).
