Old 06-19-2009, 10:07 AM   #1 (permalink)
JDMHonda
Suzuka FTW
JDMHonda's Avatar
Send a message via AIM to JDMHonda
UK vs. US alignment specs
Hey guys. I need an alignment and i was wondering if i should go with the stock, normal alignment like in the manual or the UK specs. Whats the difference. My car is a daily driver and my daily commute is about 10 miles round trip. Once every week i take it out on mountain twisty roads and like to enjoy it. Any body with the UK specs wanna tell me about how it feels different if at all? I have an AP2 if anyone cares.
Old 06-19-2009, 10:14 AM   #2 (permalink)
Nobody carez.
(Only kiddin' JD)
Didn't we just (very recently) have'a thread onn'iss?
Yuh might jus' wanna take'a gander 'cause I'm preddy sure it covered everythin' yer askin'bout.
"Correct alignment on'n S2k".
You'll find it on'a third floor with linenz, the haberdashery'n suspension.
Old 06-19-2009, 10:56 AM   #3 (permalink)
D1sclaimer
FIGHT THE POWER!!!
D1sclaimer's Avatar
If you're taking it fast or auto-x'ing, you'll probably want UK specs.
I believe gomarlins 3 uses the UK specs. I bet he'll chime in to help you.
i only date fat chicks.
Old 06-19-2009, 11:07 AM   #4 (permalink)
I prefer the UK specs, but mine is not a DD and tire wear does not concern me on this car. I believe the UK specs will cause more wear on the inside of the rear tires.
Old 06-19-2009, 11:43 AM   #5 (permalink)
turbosix
uk has more toe in the rear i believe, which makes the car a bit more stable at the expense of increased tire wear.
turbosix.net
Old 06-19-2009, 02:39 PM   #6 (permalink)
JDMHonda
Suzuka FTW
JDMHonda's Avatar
Is tire wear MUCH faster?
Old 06-19-2009, 02:48 PM   #7 (permalink)
turbosix
i dunno honestly, i have a custom alignment done by a miata guru
turbosix.net
Old 06-19-2009, 06:08 PM   #8 (permalink)
chazdawg35
chazdawg35's Avatar
Dude I told you that I'm running U.K. spec. Wear in the tires depends on the tread wear life of the tire. But you will see wear on the in side.
Old 06-19-2009, 09:58 PM   #9 (permalink)
mlc
mlc's Avatar
The UK spec alignment was really started for the early AP1 to set the rear of the car a little more because the Brits were bit%hing about the twitchy rear end. I have a MY00 which has the most extreme suspension setup, larger rear bar and all. It was setup to drive it with your ass and the gas pedal. I have two hands on the wheel, one making the turn and one ready to counter-streer. I have the UK spec alignment in the car and really like it. I dont know how it affects an AP2. The suspension was revised and "improved" as the years went on.
Kevin
Old 06-20-2009, 09:36 AM   #10 (permalink)
JDMHonda
Suzuka FTW
JDMHonda's Avatar
Aright mlc, i think thats the best answer ive heard so far. Ill just stick to the stock specs. Thanks.
08, 2005, alignment, alignmentspecscom, allignment, ap2, miata, s2000, spec, specifications, specs, stock, toe, uk, ukspec
